May 14, 2024, 01:19:19 AM *
Author Topic: Valiant, HUM on carrier.  (Read 4644 times)
Ed/KB1HYS
« on: February 02, 2011, 10:31:29 AM »
I've noticed a pronounced hum on the Valiant.  Show's up in both CW and AM mode, so it' related to the RF deck.
Oddly, on the scope it appears as a square wave modulation of the carrier, the carrier envelop has a fairly flat edge, then a drop of about 3-5% then a sharp rise back to carrier level. The low points are 3-5 times smaller than the high points, not sinusoidal at all.
I would have expected that a HV filter issue would show up as a 60 or 120hz sinusoid... so I'm thinking there is an issue with the clamp tube causing it to modulating the carrier.
More as it happens, and thank God I never put ALL the screws back into the case on that beast Wink
73 de Ed/KB1HYS
« Reply #1 on: February 02, 2011, 11:31:21 AM »
Ed,
The clamp and keyer tubes are both a common cause of hum in the Ranger/Valiant/500.  Also try it on crystal to rule out the VFO.  Note that heater/cathode leakage in the keyer tube is likely to be more pronounced  with VFO than crystal so don't let this mislead you into tearing into the VFO before trying a sub for the keyer tube.
« Reply #2 on: February 02, 2011, 11:50:28 AM »
Easy to check. Remove the clamp tube and fire it up.
k3zrf
« Reply #3 on: February 02, 2011, 12:31:16 PM »
and park that clamp tube in the spares box
dave/zrf
« Reply #4 on: February 02, 2011, 12:41:07 PM »
Spare screens R cheap enough  Grin
Page created in 0.082 seconds with 19 queries.
