Also, has anyone had to jack up the tower to replace the insulator? It looks like the Rohn tower base section has holes that could allow a sturdy pipe to support jacking.
Tom, K1JJ recently mentioned jacking up a tower to add a base plate and pier pin. Maybe he could describe how he did it.
Some larger towers with tapered base section have jacking ears. I don't know if the bolt holes in the bottom of the sections would support the weight of the entire tower without bending or tearing the metal. Perhaps some kind of bracket system that would clamp onto the rungs of the tower with multiple clamps on each leg might work.
In any case, one would need to be careful. Hazardous job, both to the operator and the tower.
