Haven't noticed anything unusual with the audio ... although I haven't looked that close at it either. Will put a scope on it tonight.
For the swept i-f alignment I used an HP-3325A sig gen/Tek 2465 scope. The procedure I followed is basically that in the CR-88 manual available from bama
http://bama.edebris.com/manuals/rca/cr88/...but with a few changes:
* Preset C75 the crystal phasing variable capacitor to half mesh.
* Determine the crystal filter center frequency and use this as the center of the i-f alignment.
* In steps 2 and 3 make the adjustments in bandwidth position 1 to get the double humps + and - 6 kc off center. Check for proper bandwidth 'shrinkage' in position 2. This is backwards from the book but seemed to work out better.
Don't be concerned with the noticeable double hump response during steps 2 and 3. With step 4 the first i-f can is added in (a single response) and the top becomes amazingly flat. The first and last i-f cans are single response and the two middle sets of i-f cans are double humped.
If you need more detailed info feel free to PM me.
