May 18, 2024, 08:36:55 AM *
Author Topic: EG252C tube, giant  (Read 2935 times)
« on: September 21, 2009, 01:48:28 AM »
We saved a huge tube, and it says "EG252C". It is about 7" diameter and 24" long. Very cylindrical. Glass except for coaxil base for filament on one end, a metal ring contact in the middle that is like a large washer inside the tube with a 2" diameter hole for the electron beam, and at the other end, the anode which is cylindrical with a roughly hemispherical face. Anode seems to be water cooled. Filament and cathode structure has a flat face with a rectangular window in which can be seen the filament. Speculation is wild.. x-ray tube, some weid triode, a klystron.. Can anyone say what it might be? I am trying to get a picture.
KE6DF
« Reply #1 on: September 21, 2009, 10:52:00 AM »
The only thing I can find googling is a site that lists it as and xray tube with no further description.
« Reply #2 on: September 24, 2009, 09:22:41 AM »
I agreed with my apprentice that he should take it. He has the time to fiddle with it. I think all I need to know is the filament voltage (most critical) and the necessary anode voltage but the anode voltage could be found experimentally as we have a 30KV transformer. Might not be enough to tickle this monster though. For low duty cycles I don't think we would use the water cooling. The oddest thing about it is that there is no apparent "direction" the x-ray beam would take. Most tubes I have seen (only 6 or 7) have a flat anode that is set at an angle to throw the x-rays in a general direction. I was thinking EG&G, but who knows. Where is that picture??
wb1aij
« Reply #3 on: September 24, 2009, 12:19:11 PM »
[The oddest thing about it is that there is no apparent "direction" the x-ray beam would take. Most tubes I have seen (only 6 or 7) have a flat anode that is set at an angle to throw the x-rays in a general direction.
Is there such as a mirror for X-rays? What type of material or surface could it be?
« Reply #4 on: September 24, 2009, 02:56:49 PM »
Size and shape sounds similar to an old RADAR tube we had in school. Top was flat though, IIRC. At least two large pigtails exiting the base, and a collar around it to hard mount it in place.
« Reply #5 on: September 26, 2009, 09:56:28 AM »
Here are some pictures finally. The anode is a hollow cylinder. I suppose the beam enters and stikes a target which I cannot see. Well I guess it will be a curio unless some data shows up. The box has 6635 4320 6004 written on it in pencil.
