Somebody here mentioned the $3 electret from Shady-O-Rack. I'm here to tell you, they are every bit as good as the D-104 quality audio.
Acoustic housing, placement and mounting of a mic element can have dramatic influence on sound. Quite a while back when I was fooling with SSB, I removed the electret element from an Icom SM-6 mic and installed it in a more substantial Shure 'high ball' mic (and relocated the preamp into the case as well). I tried all kinds of direct mount and floating element suspension schemes, but it never sounded as good as the original Icom case that consisted of a close fitting metal tube with a hole about 1/8" from the element.
