May 07, 2024, 04:45:15 AM *
Author Topic: Impedance Matching Transformer  (Read 12431 times)
« Reply #25 on: February 06, 2008, 07:11:38 PM »
Likewise, you need to reference the grid of each 811A to ground. This can be done by placing a 10k ohm resistor from each grid to ground. In your schematic, the grids appear to be just floating.
Wouldn't the grids be referenced to ground through the center-tap of the transformer?
« Reply #26 on: February 06, 2008, 07:33:51 PM »
The easy way to drive a tube modulator with a SS audio stage is a 8 ohm output transformer backwards so you step up the voltage swing. 10 volts won't cut it.
