Actually when I plate-modulate my DX-40 I won't drive the linear....too much drive power. I wouldn't gain much anyway...50 or so watts from the DX-40 versus 100 watts from the linear without exceeding dissipation from the 811A's. However, I was toying with the idea of constructing a 10-watt home-brew plate-modulated rig that would then drive the linear.
But please...as the chorus line of a tune from one of my favorite musicals, "Grease", echoes...."Tell me more, tell me more!...."
Bob, the AL811 can do a bit more than your giving it credit for. The 3 811s are good for 600 PEP. I've run one at 80 to 100 watts of carrier for an extended period of time with no detrimental effects. Your exciter might prevent this from happening, though... Some of the riceboxes, although CAPABLE of 25 to 30 watts of carrier, sound HORRIBLE at that setting without mods, etc.
Also, you CAN replace the 811s with 572s if you want to run extended key down AM. The 572s will make the amp virtually bulletproof (not idiotproof, but bulletproof) for AM, and will allow for 100 watt carrier conditions.
Just my two cents worth.
