May 20, 2024, 06:11:27 PM *
Author Topic: Looking for 6893 Tubes  (Read 1985 times)
W4AAB
« on: June 01, 2012, 09:52:19 PM »
The 6893 is the 12 volt version of the 2E26. I am converting a 1950's vintage 10m AM transmitter from 6 volt to 12 volt filaments in case I want to run it mobile. It uses a 6J6(which probably doesn't have a 12 volt equivalent and will be used with a 15 ohm 5 watt resistor to drop the filament to 6 volts). The modulators are 6AQ5's( and I have 12AQ5's?. I will be willing to trade a 6146 for one 6893.
                                                 Joe W4AAB
Page created in 0.031 seconds with 18 queries.
