Input impedance should be 50 ohms.
Shelby, be careful. You made this statement :
"but my little MFJ tuner that i just put after the amp handles 150-200 watts of carrier easily"I started running AM much like you, with an amplifier. My tuner at the time was an MFJ-962C. It was rated for 1500 watts PEP. (fine print in the manual revealed that was 1500 watts PEP DC INPUT and for SSB , not heavy duty-cycle modes).
Anyway, I ran 100 watts carrier from my DX-60 into the SB-200 into it thinking I should be fine, no problem. It was APPARENTLY OKAY for the first year, then the roller inductor started arcing right were the roller made contact on 3.885 AM. This was a slow and insidiuous process of heating up and running RF through that tuner and it took a year.
Your 200 watt carrier should give you 600 watts PEP assuming 100% modulation. You're already twice passed the STATED rated power handling for the tuner and I promise you that MFJ OVERSTATES their specs.
The point of my post? Use that "little MFJ tuner" if you want too but be looking for something bigger because it will fail at some point if you keep pumping 200 watts of carrier into it. I believe you already have some experience with AM carrier ratings vs. PEP ratings.
