June 26, 2024, 01:41:08 AM *
Author Topic: BC-342 VOLTAGE REQUIREMENTS..  (Read 2819 times)
ve6pg
« on: August 25, 2010, 05:33:59 PM »
..i have a bc-342, that requires an outboard p/s. ..what are the required voltages for this receiver?..
..tnx..
..tim..
..sk..
KC4VWU
« Reply #1 on: August 25, 2010, 06:14:59 PM »
I believe it's 235-240v B+, close is good; and the heater voltage. Look around the net for the RA-20 P/Supply specs. Check for B+ rail to ground shorts before you hook it up though.
73, Phil
WA2ROC
« Reply #2 on: August 26, 2010, 06:59:08 AM »
Years ago, I had a brand new BC-342 packed in a shipping crate that had an onboard 110VAC power supply built in.
Maybe someone took this guy's PS out?
The 250V B+ sounds about right.  I felt it once or twice...
Dick Pettit WA2ROC
Vintage Heathkit Equipment
N8ETQ
Mort
« Reply #3 on: August 26, 2010, 10:06:32 AM »
Hey Tim,
     TM 11-850 is online at:
http://www.pestingers.net/PDFs/Other_radio_stuff/Military%20manuals/TM%2011-850%203%20Sep%2046%20NJ7P%20AS.pdf
      The RA-20 is nice but the RX often had a DM-21 dynamotor for 12VDC
or a DM-21CX for 24-28VDC.
GL
/Dan
ve6pg
« Reply #4 on: August 26, 2010, 04:14:36 PM »
..sorry guys...i guess it is a BC 312,..so..250-300v sounds good...
..sk..
KC4VWU
« Reply #5 on: August 26, 2010, 08:38:02 PM »
Basically, they're the same box.
Phil
Page created in 0.05 seconds with 19 queries.
