June 25, 2024, 10:04:43 PM *
Author Topic: AAAAHHGGGG!!! Cursses! Foiled again!  (Read 3304 times)
K7NCR
« on: September 26, 2009, 08:55:27 PM »
I'm making progress in my station set-up. Repaired a loose connection in my tuner, and 40M is coming in great tonight! I try to tune the TX, and NO OUTPUT! I double checked all the connections, etc, and finally discovered my only DOWKEY relay has an open coil!  Angry Angry Angry Angry Angry I wanted to work the CX this weekend! I was thinking of a quick junk-box TR box with this relay:
http://www.radioshack.com/product/index.jsp?productId=2049721
Any thoughts on the ability of this relay at RF? Just my Apache, no amp.
Norm
K1HH
« Reply #1 on: September 26, 2009, 09:03:20 PM »
I believe it will work OK; I use one of those instead of a Dow-Key relay on my DX-60; a little less powerful, but I've never had any trouble with it. Actually have two of them in parallel to get more poles. Put a little piece of velcro on the top of the relay case and another piece where you want it to be.  Go for it!
Rodger
K1HH
« Reply #2 on: September 26, 2009, 09:18:30 PM »
I have used these with a Valiant and DX-100 with no problems.   These will easily handle this power level; as long as you have a reasonable antenna match neither the current nor voltage will be a problem.
K7NCR
« Reply #3 on: September 26, 2009, 10:30:44 PM »
Cool! I thought so. It is DPDT, so I could parallel the contacts. Rat shack opens at 11 AM Sunday, so I can still make it for Sunday Night operation.
Norm K7NCR
« Reply #4 on: September 26, 2009, 11:02:10 PM »
You really don't need to parallel the contacts but if you need both sets it won't hurt.  I use one set for the antenna and the other for receiver muting.
K7NCR
« Reply #5 on: September 27, 2009, 12:31:32 AM »
Using the Apache with the Mohawk, so it has a dedicated pair of terminals that mute the receiver. On the other hand, if i use the relay contacts, it would mute the receiver when I'm using the SB-10. That would work FB!
I need to come up with a switching setup for when I get the Marauder fixed, to allow me to use it and the Apache both with the Mohawk.
On another note, I just scored a decent looking Seneca on e-bay for $100. I love just fillin' up the shack with them Heap Big Injuns!  Now I need a Heath 6M converter for my Mohawk, so I can go AM on the "magic band"!
« Reply #6 on: September 27, 2009, 04:15:53 PM »
Shouldn't be a problem at all.  Especially on 40m.  My FT-301 uses that capacity relay and it's over 30 years old.  No problem yet.  DowKeys are JUNK!!!  I would NEVER use one in my station.  When my friend Gard, W1UGV did the bypass relay conversion in my Courier, he used an open frame relay -- a bit more rugged -- and it works just fine -- but then, that beastie puts out a bit more power than your average 100 watt rig.
Al
K7NCR
« Reply #7 on: September 27, 2009, 04:47:44 PM »
Fixed! I had an old 2 position coax switch in a little chrome housing. I removed the switch, stuffed the relay in, wired it to the existing 3 SO239 connectors already built into the switch, ran pigtails out to a terminal strip I glued to the housing. Works FB, takes up little more room than the DOWKEY relay, and has an easy to access extra set of contacts. Now I have output! I'll keep an ear open this evening for some CX stations, and whoever else wants to come out and play!
Norm K7NCR
Page created in 0.074 seconds with 19 queries.
