December 11, 2025, 01:17:58 AM *
Author Topic: Ball Chain Source  (Read 4010 times)
wb3eii
« on: May 05, 2024, 03:38:58 AM »
Can anybody point me to the correct chain that is used on the band change mechanism for the National Nc-300 receiver?
 I have tried a few different 'new' chains, and I believe the ones currently being made are of a slightly different pitch or size, compared to the remains of the original chains.
 So I'm probably looking for some new-old-stock type of deal, someone who has a reel of this stuff dating from 50 years ago.
 ANYONE?
Chuck...K1KW
« Reply #1 on: May 05, 2024, 11:07:44 AM »
Hi,
I don't know what the correct chain is but if you know its dimensions try matching them to the many varieties available at McMaster Carr here:
I would think a "standard" size was used even back then!
https://www.mcmaster.com/products/ball-chain/
-Chuck
73, Chuck...K1KW
Carl WA1KPD
« Reply #2 on: May 05, 2024, 02:05:11 PM »
The new ones are all metric. You can substitute, but the drum will not be in alignment on all bands.
Maybe someone has a parts unt?
KD1SH
« Reply #3 on: May 05, 2024, 03:18:35 PM »
  You might check with these guys:
https://www.ballchain.com
  Made in the U.S, apparently, and the sizes they list are given in standard SAE values, not metric, although they do indicate the metric equivalents.
WA2SQQ
« Reply #4 on: May 06, 2024, 07:43:44 AM »
This would make an interesting episode of “How it’s Made”
KW6T
« Reply #5 on: June 24, 2024, 12:11:35 AM »
"Wirelessgirl.com" discusses this item in her page on NC-303 but has no source.
An Amazon search for "ball chain" yielded a lot of results and sizes (of balls, I presume) 2.4mm, 3.0mm, 3.2mm, 4.5mm, #10, #8, etc.  The pitch is likely going to be the bugger.  If you can match the ball size, perhaps you can interpolate/approximate the pitch size in the photo.
if you find a suitable chain, please post the source.
Russ
KW6T
Russ
"Cheap" is rarely the least expensive.
WA4WAX
« Reply #6 on: June 24, 2024, 08:26:44 PM »
Have a look guys!
https://www.ballchain.com/chain-sizes/
Speaking of balls and chains:
You can almost smell the cigarettes and the Southern Comfort.
https://www.youtube.com/watch?v=X1zFnyEe3nE
KD1SH
« Reply #7 on: June 24, 2024, 09:10:55 PM »
As I posted back on May 5th, further up the thread.
Never saw a reply from the OP, so I don't know if it worked for him.
