December 08, 2025, 12:54:47 AM *
Author Topic: D104 talk  (Read 28647 times)
N9NEO
« on: February 19, 2005, 10:39:04 AM »
Am trying to get D104 to do ptt for me.  The D104 that I have has what looks to be a 2 transistor preamp (9v battery)and also has a toggle switch on base.  The toggle switch installation looks a little mickey-mouse, but was probably factory.  Mic cable is a sheilded coax with a red and black pair outboard of the sheild.  Looks like there's been a few in here before me playing around, but not too FU.
So I got this thing all hooked up and no ptt.  Seems the black wire was cut and just hanging loose.
What's got me stymied here is the amount of wires coming into the base from up above.  looks like  a sheilded pair for the audio, and then a half dozen small guage.  Blk, wht, red w/purple stripes, drk blu, red/wht, grn/wht.  Looks like the red/wht goes to switch on bottom labeled R&E, which I think means relay & electronic.
Ok, so any info would be good here.  Don't know if schematic available on web???
One other thing, and most important.  Should I even bother with trying to get the big chrome switch on the D104 to operate, or should I just swap out the little toggle switch on the base with a two pole?  Use one pole for ptt, and the other to power up the preamp?
NEO
PS, thanks to Rene - MVP, and Bob - TAX for help so far.  Have done the TAX audio mods and gotten FB audio reports with the D104
N5RLR
Extra With A Side Of Fries
Supremely Lurking
« Reply #1 on: February 19, 2005, 01:36:31 PM »
Tried a lookup on the Web, and darned if I couldn't find a schematic for it.
IIRC, the switch in the neck is a 3-or-4-pole.  One pole takes the 9V negative to ground to engage the amp on Transmit; one pole switches the audio input of the rig to ground on Receive, and to the amp on Transmit; one pole switches a common wire [taken to ground on the Electronic setting, I believe] between Speaker on Receive, and Transmit on, well, Transmit [on Relay setting the common goes to the cable].  [Disclaimer:  This is from very fuzzy memory, so anyone with a diagram feel free to confirm or correct me!]
I did, however, find this wiring code for the cable:
White: Audio
Shield: Ground
Yellow: ?
Blue: Relay common [see above]
Red: Transmit
Black: Speaker
Hope this is of some help; best I could do from work.   :mrgreen:
Also...get the PTT bar working, even if you have to do a complete rebuild of the mic.  A D104 is not a D104 unless you can "choke" it. :badgrin: [I've not been fond of Astatic's PTT "base bar" on the newer models.]
Michael
Licensed Since 1990  Cheesy
« Reply #2 on: February 19, 2005, 04:12:46 PM »
What is the lastest on the D 104?   I've heard that Astatic was sold to, or is now, CTI Audio......I called them about a year ago and they had no more replacement cartridges avaivable for the D 104 altho they had new mics for sale..Something was said about discontinuing the D 104.......I think someone on this board lives near the factory and has a relative working there..(.Conneaut, Ohio?)  Inquiring minds want to know........73       Steve
WV Hoopie
« Reply #3 on: February 19, 2005, 04:52:39 PM »
NEO,
BAMA has some info.
http://bama.edebris.com/manuals/astatic/
73's
     Craig
K6JEK
RF in the shack
« Reply #4 on: February 19, 2005, 04:52:49 PM »
I have a JPEG of the schematic.  Would you like me to mail it to you?
Jon
N9NEO
« Reply #5 on: February 19, 2005, 05:27:05 PM »
Jon,
Please Email schematic to yzordderrex@verizon.net if it isn't too much trouble.
NEO
K6JEK
RF in the shack
« Reply #6 on: February 19, 2005, 10:22:16 PM »
Quote from: N9NEO
Jon,
NEO
It should be in your in box momentarily
« Reply #7 on: February 20, 2005, 12:09:10 AM »
A few years ago I saw a mic for sale at a hamfest. It looked like a D-104, but upon close inspection it turned out to be an exact copy, made in Japan, with some off-brand name.
Since someone made a D-104 clone, I wonder if they might also make clones of the cartridge. I have never seen the Jap 104 clone advertised anywhere.
As many 104's as there are out there, you would think someone would offer an aftermarket cartridge if Astatic has decided to discontinue manufacture. The technology is well known and the mic has been in production since 1933.
W1GFH
« Reply #8 on: February 20, 2005, 01:07:50 AM »
Quote from: k4kyv
Speaking of eBay... :grin:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=48695&item=5752742787&rd=1&ssPageName=WDVW
WB2CAU
« Reply #9 on: September 02, 2013, 04:35:46 PM »
The D-104 clone is an American Electronics 95-328.  According to a long time friend who formerly worked at Astatic, Astatic took American Electronics to court over the infringement and won the case against them.  It ended American Electronics from selling any more 95-328s.
Since there was no attempt to sell the microphone as an Astatic D-104, and AE merely copied the appearance, I'm wondering under what basis Astatic won the suit. I'm no legal expert by any means.
I previously worked for a well-known product safety testing lab and it was quite common for submissions to my lab by competing companies to make copies of each others products and not be faced with litigation since there was no copying of trademarks or brand names.  Unauthorized use of brand names or trademarks is counterfeiting, but that did not occur in this case.
Since Astatic eventually was faced with the inability to obtain the raw materials to produce any more crystal cartridges, leading to the discontinuance of the D-104, I feel that they probably should have formed an alliance with the Japanese manufacturer that produced the 95-328 for American Electronics.  I guess they shot themselves in the foot instead.  Now no one makes a D-104, a similar clone, or original type replacement cartridges anymore.
I suppose that some enterprising Chinese manufacturer could probably produce a reasonably close copy of the D-104 crystal cartridge, in its original size with all of its original sonic characteristics, but with relatively low demand they probably don't have the financial motivation to do so.
Pictured is the American Electronics 95-328, not the D-104.
Detroit47
« Reply #10 on: September 02, 2013, 05:34:44 PM »
I bought a final edition D104 Silver Eagle at Dayton about 15 years ago. It came in a display case. I have never opened the box. It is a true shelf Queen. The Astatic people were set up inside Hara. The fellow I purchased it from told me that the tooling to make the components was worn out, and the low demand didn't justify the expense of retooling. So it is just a story of not enough demand to support the cost. There is a final edition on Epay right now.
http://www.ebay.com/itm/NIB-Astatic-Final-Edition-Silver-Eagle-D104-Sealed-In-Box-/300832404095?pt=US_Radio_Comm_Microphones&hash=item460b02327f
W1FVB
VB Radio
« Reply #11 on: September 02, 2013, 08:42:52 PM »
Some D104 schematics that I've scrambled around over the years...:
https://www.dropbox.com/sh/b9tha5izsan9p06/vrf22oaqAl
vbradio.wordpress.com
MikeKE0ZUinkcmo
« Reply #12 on: September 03, 2013, 08:46:23 AM »
This, I believe is the most common amplifier used in the D-104 mics.
If this is not your particular mic, at this link I have approximately 15 schematics and and pages of print information on the various D-104 mics.
HTH
Mike
Mike KE0ZU
« Reply #13 on: September 03, 2013, 10:06:13 AM »
One of Mine has a copy pasted on the inside of the base plate. Thought they all came that way, but maybe not.
MikeKE0ZUinkcmo
« Reply #14 on: September 03, 2013, 07:28:12 PM »
After reading your post I went and looked at mine.  Some had schematics, some didn't, no conclusion here.
Mike KE0ZU
« Reply #15 on: September 03, 2013, 10:53:56 PM »
When mine died from the heat, I replaced the element with that from a EV-635A dynamic glued into an aluminum donut plate as a 'stopper'.
Sounds FB, prolly never go bad.  Looks a lot like what's in the Turner 99 construction, looks stock outside.
Detroit47
« Reply #16 on: September 03, 2013, 11:07:07 PM »
What kind of rig are you planing to put the mic on? I have found that on tube radios a D104 works better without the pre amp. I usually just jump it out.  Unless you are looking for that background audio effect.
« Reply #17 on: September 03, 2013, 11:53:21 PM »
One of the problems with starting up a thread after 8 years being dormant. The thread was re-started because WB2CAU added a post about a D-104 clone. One would think the original poster has moved on to other projects after 8 years.
wa3dsp
« Reply #18 on: September 04, 2013, 12:43:54 AM »
Well since someone asked the question and the thread is opened again I will throw my 2 cents in.
I have a collection of D104's and I use them with just about every rig I have. The original Astatic bipolar preamp is not very good and does not supply the very high impedance the element wants to see. I use a simple source follower (MPF102 or equiv.) "preamp" in each stand. It is really not a preamp but more an active impedance matching circuit. The D104 elements want to see a very high impedance for proper operation. Preferably 5 megs or more. I typically use a 7-10 meg "gate leak" resistor. The source following has a low impedance output and matches just about anything. It works well with today's 600 ohm mic input rigs as well as my Ranger with high impedance input. Of course in the case of the Ranger or any other high impedance input rig you would not really need the source follower but it does not hurt to have it in there. If you do run the D104 raw to a tube type rig it is a good idea to raise the grid leak to 5-10 megs. Most have a 1 Meg or less grid leak.
Power for the FET can come from a battery using an available switch contact on the D104 or I use the 8 volts available on all modern rigs mic connectors. I added an 8 pin mic connector to my Ranger wired in Kenwood pinout with 8 volts from an internal regulator.
The circuit is simple but if anyone needs it I can attach it in another message.
« Reply #19 on: September 04, 2013, 01:02:53 AM »
No 'Ham' rigs per se.  All TX are HB, more along the lines of 30's or vintage BC gear.
All have a hard 600Z  +4dB input, driven by a soft limiter/compressor from an audio preamp.
« Reply #20 on: September 04, 2013, 06:44:02 AM »
It's generally not a good idea to necro threads. Just start a new one.
Here's a simple FET-based matching circuit for the D-104.
http://w1cki.net/D104schem.htm
wa3dsp
« Reply #21 on: September 05, 2013, 01:19:38 AM »
The D104 "preamp" I use and the Astatic D104 schematic.
I never found it necessary to bypass the element although you may need to if you have RF issues.
* D104 Fet Source Follower.pdf (18.9 KB - downloaded 244 times.)
« Reply #22 on: September 06, 2013, 06:52:46 AM »
Moderators:
Can the AMFONE software clean out old posts over a certain age? Or if the thread is over a certain time; someone wanting to bring it back up would get a message to start a new thread.
WB2CAU
« Reply #23 on: September 06, 2013, 09:47:52 AM »
What exactly is the 'problem' with adding to an 8 year old discussion anyway?  The information I added was discovered long after the last post was made and I thought I had something to share that was informative.  The subject matter has not expired and other posters have continued the original topic with good input to the discussion. Many of the posters were not participants on this site when the thread was started in 2005.  The topic is new to them.
Why is it a sore point to the moderator and the administrator?
« Reply #24 on: September 06, 2013, 09:52:35 AM »
I don't get that either. Maybe adding a disclaimer like "I know this is an old thread but..." will keep you out of radio prison. Sri fer the hijack Jack.
Page created in 0.065 seconds with 15 queries.
