June 29, 2024, 03:17:50 AM *
Author Topic: Neutralizing Cap  (Read 4223 times)
K9ACT
« on: October 21, 2007, 02:06:58 PM »
Going to two tubes on my 8000 means that the neut cap has to be twice the value.
According to the handbook, I need a spacing of .250" for 1600 VDC AM.
Using the cap that I made for the single tube requires a spacing of about .1" to get to the needed value (about 17 pF).
This can be seen in the pic attached and to get there with this design, I have to make another one about 5" in diameter.  This would be a rather big klunky beast and it seems like there should be a better way.
The bias supply has been moved under the chasis and the new tube is where that was in the pic.
What do people use for N/C's for this application?
js
p.s.  I don't have much luck attaching pics to these messages so if it's not here, go to http://schmidling.com/rfd4.jpg
js
* rfd4.jpg (0 KB - downloaded 160 times.)
« Reply #1 on: October 21, 2007, 02:44:07 PM »
some use a treaded rod placed  near the tube(s) to be nutered; use a ceramic feed through insulator and raise the rod up/down to change the capacitance....  or so i'm told...  Thats what i'm gunna do with my 813/810 maul...   klc
K9ACT
« Reply #2 on: October 22, 2007, 12:16:44 AM »
Not sure I can picture that but it sounds more like a "gimmick" cap for a tetrode.  You need a serious cap for big triodes, especially in parallel.  In my case, about 16 puff.
js
« Reply #3 on: October 22, 2007, 12:29:54 AM »
yes, ur right...........  I'M doing a PP 813 driven by PP 810 mudulators ... the brain (if its still in there) got it backwards. Anyway  good luck, gud night ............  klc
« Reply #4 on: October 22, 2007, 09:32:26 AM »
Hi Jack....... are these tubes in PP or parallel ?
Tom's parallel 813 rig uses a nifty neuter setup.
Check it out here.
813s X 813s
K9ACT
« Reply #5 on: October 22, 2007, 12:29:41 PM »
Check it out here.
813s X 813s
Again, that is for tetrodes that are not supposed to need neutralizing in the first place.  I do not understand quite how it works anyway.
I solved the problem in a way that I do understand.
By coincidence, (Mack) I picked up two small NC's at the last hamfest, only because of all the work it took to make mine.  They are two small to do anything with but I was able to disassemble them and put it back together on one mount in parallel.  They are now about 6 pF with .25" spacing.  This in parallel with the original at .25" gives me just what I need.  A bit Rube'ish but it works.
Pic attached....
Gonna fire it up after my coffee.
js
WA1HZK
« Reply #6 on: October 27, 2007, 05:04:10 PM »
Big Triodes, Big cap. I ended up with around 10 pf. on a trimmer that had the same spacing as the final plate tuning cap in my 833 rig.
Keith
WA1HZK
www.criticalradio.com
www.criticalbattery.com
www.criticaltowers.com
www.criticalresponder.com
