May 18, 2024, 08:52:06 AM *
Pages: 1 2 [3]   Go Down
Author Topic: New Class E transmitter status  (Read 22610 times)
kb3ouk
The Voice of Fulton County
« Reply #50 on: February 28, 2013, 08:09:48 PM »
High percentages (well beyond 100%) of positive peak modulation also make the effects of selective fading more severe.
High positive peaks will also wreak havoc with a fast AGC, and if you are running a receiver that doesn't allow manual RF gain control or the ability to switch to a slow AGC (some modern riceboxes are this way), it will render anyone running big peaks almost unintelligible. My FT-901 has a fast/slow AGC switch and I'm glad it does, since there are some guys that I would not be able to copy at all if it was fast only and had no way to slow it down.
« Reply #51 on: February 28, 2013, 09:08:31 PM »
Maybe eventually we all will run sync detectors and the wavelet problem will go away.
Some wavelets are hi hi FB.
Otherwise, maybe eventually we will all turn slopbucket.
« Reply #52 on: February 28, 2013, 09:56:07 PM »
Here are some wavelets, and without wavelets. I found it interesting that with a diode detector, the altered waveform via PNCL (Progressive Negative Cycle Loading) sounds quite good since the distortion is largely even order whereas a diode detector reacting to wavelets can make the most annoying sound. The waveforms depict positive peaks at about 150%.
The waveform and PNCL circuit are from a Central Electronics 20A using an E34L Power Pentode in the final. This rig can do about 45 watts PEP output.
« Reply #53 on: February 28, 2013, 10:32:04 PM »
No shame in that. Heck, I turned "slob" bucket 40 years ago. I spend half my on-air time doing ssb DXing and love it.
Setting up a powerful, clean and effective ssb station is as difficult as doing the same thing on AM. I find it pays to have several modes and dives to hang out in to keep it fresh ... :-)
Pages: 1 2 [3]   Go Up
