June 22, 2024, 09:54:38 PM *
Author Topic: Information on Kenyon plate transformer  (Read 4127 times)
wb3eii
« on: April 07, 2012, 11:19:46 PM »
 One of my Craigslist finds is a plate transformer.
 Made by Kenyon Transformer, It is a "Type S 13342".
 It has dual primaries, 120-240, and the output is 1400-0-1400.
 This weighs somewhere around #150, seems to be in good shape.
 I am currently using it to drive my 4-1000a amp,  when I drive it hard, I can hear the transformer sing.(is this an issue)?
 Does anyone have an old Kenyon catalog?
 I am curious what the amperage ratings are.
 73 AB3HT
KE6DF
« Reply #1 on: April 07, 2012, 11:43:38 PM »
I think the S series Kenyon transformers were custom designs for OEM customers.
I have never found anyone with a catalog for them, and doubt one exists.
You might go the T series catalog (from the Web) and compare it to one of those of similar size and weight.
That should give you an idea of the current rating.
Dave
« Reply #2 on: April 08, 2012, 12:15:07 AM »
Singing my not mean anything. A rule of thumb is to load it until the AC voltage drops to 90% if the unloaded value, that is about the current rating.
What circuit are you using for the rectifier?
« Reply #3 on: April 08, 2012, 03:14:28 AM »
Five digit part numbers are specials.  They're not regular catalog models.  Just guessing, 2800V CT at 150Lbs, it's probably close to an amp current rating, maybe more.
wb3eii
« Reply #4 on: April 08, 2012, 11:55:32 AM »
"What circuit are you using for the rectifier? "
 Full wave ,center tap, capacitor filter.
 Cap bank is a bit large, 14 cans in a row,(7 on each side of center) 450volt electrolytic, 2400 mf each.
 Bleeder resistors are 3 units each of 5watt 100k ohm ceramic, parallel connected across each cap.(42 resistors total)
 73, AB3HT
« Reply #5 on: April 09, 2012, 03:00:15 AM »
Do you mean A or B or something else? I am confused by having a cap bank on each side of CT and having a FW CT setup.
anyway, 'talking' may be due to the cap input filter. The peak secondary currents could be large maybe 5A.
wb3eii
« Reply #6 on: April 09, 2012, 08:10:29 PM »
Diagram "A" is the setup.
 I had worried that the  2400mf caps would be a problem, but I had a few hundred of them, sold most at hamfests over the years, used what I had left.
 Amp runs fine, no issues in the 2 years I have had it.
Most of the time,I can not make the iron sing, as I drive it only to about 1200 watts output.
 73, AB3HT
« Reply #7 on: April 10, 2012, 08:05:00 AM »
Be wary of running that transformer with a doubler or bridge setup. Running the center tap that high above ground could cause an insulation breakdown failure.
I learned this the hard way and fried a couple of nice plate transformers.  Cry  Cry
Figure "B" is really the prefered way to run those old transformers unless you know that they were specifically rated for FWB use.
Page created in 0.05 seconds with 19 queries.
