I've noticed a pronounced hum on the Valiant. Show's up in both CW and AM mode, so it' related to the RF deck.
Oddly, on the scope it appears as a square wave modulation of the carrier, the carrier envelop has a fairly flat edge, then a drop of about 3-5% then a sharp rise back to carrier level. The low points are 3-5 times smaller than the high points, not sinusoidal at all.
I would have expected that a HV filter issue would show up as a 60 or 120hz sinusoid... so I'm thinking there is an issue with the clamp tube causing it to modulating the carrier.
More as it happens, and thank God I never put ALL the screws back into the case on that beast
![Wink](https://amfone.net/Amforum/Smileys/classic/wink.gif)
