Title: Ball Chain Source Post by: wb3eii on May 05, 2024, 03:38:58 AM Can anybody point me to the correct chain that is used on the band change mechanism for the National Nc-300 receiver?
I have tried a few different 'new' chains, and I believe the ones currently being made are of a slightly different pitch or size, compared to the remains of the original chains. So I'm probably looking for some new-old-stock type of deal, someone who has a reel of this stuff dating from 50 years ago. ANYONE? --... ...-- Title: Re: Ball Chain Source Post by: Chuck...K1KW on May 05, 2024, 11:07:44 AM Hi,
I don't know what the correct chain is but if you know its dimensions try matching them to the many varieties available at McMaster Carr here: I would think a "standard" size was used even back then! https://www.mcmaster.com/products/ball-chain/ -Chuck Title: Re: Ball Chain Source Post by: Carl WA1KPD on May 05, 2024, 02:05:11 PM The new ones are all metric. You can substitute, but the drum will not be in alignment on all bands.
Maybe someone has a parts unt? Title: Re: Ball Chain Source Post by: KD1SH on May 05, 2024, 03:18:35 PM You might check with these guys:
https://www.ballchain.com Made in the U.S, apparently, and the sizes they list are given in standard SAE values, not metric, although they do indicate the metric equivalents. Title: Re: Ball Chain Source Post by: WA2SQQ on May 06, 2024, 07:43:44 AM This would make an interesting episode of “How it’s Made”
Title: Re: Ball Chain Source Post by: KW6T on June 24, 2024, 12:11:35 AM "Wirelessgirl.com" discusses this item in her page on NC-303 but has no source.
An Amazon search for "ball chain" yielded a lot of results and sizes (of balls, I presume) 2.4mm, 3.0mm, 3.2mm, 4.5mm, #10, #8, etc. The pitch is likely going to be the bugger. If you can match the ball size, perhaps you can interpolate/approximate the pitch size in the photo. if you find a suitable chain, please post the source. Regards, Russ KW6T Title: Re: Ball Chain Source Post by: WA4WAX on June 24, 2024, 08:26:44 PM Have a look guys!
https://www.ballchain.com/chain-sizes/ Speaking of balls and chains: You can almost smell the cigarettes and the Southern Comfort. :-) https://www.youtube.com/watch?v=X1zFnyEe3nE Title: Re: Ball Chain Source Post by: KD1SH on June 24, 2024, 09:10:55 PM As I posted back on May 5th, further up the thread. AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
Never saw a reply from the OP, so I don't know if it worked for him. Have a look guys! https://www.ballchain.com/chain-sizes/ |
