Title: NC-300 Xtal Marker Too High in Freq Post by: W1KSZ on March 30, 2017, 05:59:05 PM I have a HB Xtal Oscillator that someone built using the National circuit as a guide.
At Max C on the Trimmer Cap it is still about 44 CPS too high. I tried adding another 12 pf to the 20 pf Trimmer Cap, but that killed the oscillation. Any ideas on what I might try next ? Thanks, Dick, W1KSZ Title: Re: NC-300 Xtal Marker Too High in Freq Post by: KB2WIG on March 30, 2017, 07:34:29 PM Parall or series.? KLC Title: Re: NC-300 Xtal Marker Too High in Freq Post by: W1KSZ on March 30, 2017, 08:19:01 PM If you mean the location of the Trimmer, it's parallel to the Xtal.
If you mean resonance, I think it's also parallel. 73, Dick, W1KSZ Title: Re: NC-300 Xtal Marker Too High in Freq Post by: W4AMV on March 30, 2017, 10:43:55 PM Dick, can you post the circuit? Do you know the crystal specification? The required load capacitance? Assuming it is 32 pF implies the crystal at resonance requires 32 pF total load C and the crystal looks like 32 pf of equivalent inductive reactance at 100 kHz. I can't recall what 100 kHz xtal typical look like. I have a few and I'll take a measure and see. If it is a Colpitt oscillator arrangement, then the total C around the xtal including device loading and C feedback etc... should amount to 32 pF. Need to identify the circuit configuration. Alan
Title: Re: NC-300 Xtal Marker Too High in Freq Post by: W1KSZ on March 30, 2017, 11:33:22 PM Attached is the schematic of the National Calibrator.
73, Dick, W1KSZ Title: Re: NC-300 Xtal Marker Too High in Freq Post by: KA2DZT on March 31, 2017, 12:18:00 AM Your 100Khz oscillator is off by 44hz. That error is less than 5/100% What are you using to read the frequency??
Title: Re: NC-300 Xtal Marker Too High in Freq Post by: W1KSZ on March 31, 2017, 12:59:29 AM I have an HP 5334B Counter whose Reference Oscillator is a Trimble Thunderbolt GPSDO.
44 CPS @ 100 Kc = 13.2 Kc @ 30 Mc. Not exactly accurate. 73, Dick, W1KSZ Title: Re: NC-300 Xtal Marker Too High in Freq Post by: KA2DZT on March 31, 2017, 01:33:01 AM I'm still using a HP-5245. I calibrated the time base oscillator against WWV (IIRC). Don't remember how I did it. Don't think back in the 1950s, when most of this stuff was made, they had anything that could read frequency that close. In the late 1960s I worked for Westinghouse Electric. We had one of those giant 200lb HP counters, 500 something. Don't remember the exact number. We used it to check and calibrate the lesser HP counters that were used around the plant. The monster counter was suppose to be 10 times more accurate than the lesser ones.
Title: Re: NC-300 Xtal Marker Too High in Freq Post by: WBear2GCR on March 31, 2017, 08:45:10 AM I have an HP 5334B Counter whose Reference Oscillator is a Trimble Thunderbolt GPSDO. 44 CPS @ 100 Kc = 13.2 Kc @ 30 Mc. Not exactly accurate. 73, Dick, W1KSZ Is that correct?? It's not being multiplied by mixing. It's just the harmonic due to the rise time of the leading edge, no? I'd check that theory with a solid state rig of known calibration, like vs. WWV and look at the calibrator signal at 5mHz and 10mHz, etc and see if it is actually off many kHz or not. Title: Re: NC-300 Xtal Marker Too High in Freq Post by: W1KSZ on March 31, 2017, 11:17:39 AM Back in "the day" I used to borrow the lab's 5245L to check my Xtals at home.
At the time, it was the best we had at the time. Today, we have the GPS system and can use that to discipline a 10 MHz Oscillator such that we now have Frequency measurement capabilities that far exceed those available in the 60's. Look at the articles written by N1JEZ, you can build a simple one for less than $100. A few years ago, the Trimble Thunderbolt was available from Chinese Breakers for around $20, but that supply has dried up. I use a Trimble with an SRS FS710 Splitter to supply 10 MHz to all my counters and as a bench reference. With an HP 5345A and a 1,000 Second Gate Time, I can measure Frequency, accurately, down to the milliHertz range. Pretty awesome when I can look at the difference between a GPSDO and a Rubidium. 73, Dick, W1KSZ Title: Re: NC-300 Xtal Marker Too High in Freq Post by: KA2DZT on March 31, 2017, 11:46:51 AM OK FB, sounds like your freq measurements are accurate. Getting back to the problem, most likely the 100Khz crystal is off. Can you open the crystal case?? I think there are some things you can do to bring the freq down. I think some pencil lines is one of them. Someone here may know more.
Fred Title: Re: NC-300 Xtal Marker Too High in Freq Post by: KU8L on March 31, 2017, 12:13:13 PM It doesn't take a cal lab setup to get to 44 Hz on a calibrator. Measuring beats against an OTA signal like WWV can get to a Hz or 2. Now, it isn't gonna stay there for long, but you can surely measure it.
All the frequency measurement folks did it that way prior to having access to GPS locked references. It is how the ovenized ref oscillators were typically adjusted. You can do it now using soundcard software and a laptop. FWIW Curt KU8L Title: Re: NC-300 Xtal Marker Too High in Freq Post by: W4AMV on March 31, 2017, 02:51:07 PM Hi Dick. Thanks for the schematic. The 6AK6 is ~ 3.6 pF and the circuit C looks like the max is 23 pF. So at 27 pF it would appear that the 100 kHz crystal is not designed for a 32 pF load C. I believe the crystal package is a HC13/u and not sure if the holder C would account for an additional 5 pF. I have a few of these 100 kHz crystals in the old style HC13/u package and I'll make a measurement and see what the crystal looks like. If it is 32 pF equivalent at 100 kHz that is a clue. As a prior post implied, if the crystal has aged, it may not be possible to load it sufficiently to bring it down to 100 kHz. In doing so lowers the reactance of the parallel circuit to the point that the oscillator will not start. Again, measuring a good xtal of this style will provide some clues as to what can be done with this circuit to pull the xtal. Alan
Title: Re: NC-300 Xtal Marker Too High in Freq Post by: W1KSZ on March 31, 2017, 03:27:16 PM The Xtal is an old Petersen Radio Type Z6-A. Older than dirt. Could be it never
worked right and I am just pushing that old boulder up a hill. I think I should junk this thing and look for a real Xtal Calibrator. The Nationals are a tad pricey, but the Heathkit HRA-10-1 looks like it will do, just need to re-wire the octal plug. 73, Dick, W1KSZ Title: Re: NC-300 Xtal Marker Too High in Freq Post by: Carl WA1KPD on March 31, 2017, 04:08:25 PM Hi Dick,
44 CPS? If this for use on a boat anchor rcvr bother? You are never going to hear the difference. Carl Title: Re: NC-300 Xtal Marker Too High in Freq Post by: W4AMV on March 31, 2017, 04:55:58 PM Yes, I agree 44 Hz. Quite fine. In any case after effort, my analyzer stops at 100 kHz! However, I have a vector Z meter and with care and patience, I was able to set it to 100 kHz spot on. Viola, 32 pF inductive. So, for what it is worth, the 100 kHz xtal as used for example in the Drake 2B calibrator and others, correlates to 32 pF. Alan
Title: Re: NC-300 Xtal Marker Too High in Freq Post by: Tom WA3KLR on March 31, 2017, 06:13:12 PM Look for some more 100 kHz xtals at the next hamfest or your local buddies junk boxes.
Title: Re: NC-300 Xtal Marker Too High in Freq Post by: W1KSZ on March 31, 2017, 07:16:14 PM I agree, 44 cps @ 100 Kc may not seem like much but when you multiply it by 300
to get a marker at 30 Mc, it can be substantial. For example: It reads 100.044 Kc, multiply that by 300 and you get 30, 013.2 Kc. So you can see my A/R need to get it closer !! 73, Dick, W1KSZ Title: Re: NC-300 Xtal Marker Too High in Freq Post by: Carl WA1KPD on March 31, 2017, 08:53:45 PM Got it.
I "assumed" you were talking about compared to 10 MCS WWV. My standard. My bad Carl Title: Re: NC-300 Xtal Marker Too High in Freq Post by: W1KSZ on April 01, 2017, 02:01:53 PM WWV is OK as a first approximation, but ever since I got hooked on the GPSDO,
my bar has been raised to astronomical heights. I actually bought an HP 5345 Counter so I could use the 1000 second gate time to measure the Frequency difference between my GPSDO and a couple of Rubidium Standards I acquired. There's a Reflector called "Time-Nuts" that makes me and my obsession look positively primitive !! 73, Dick, W1KSZ Title: Re: NC-300 Xtal Marker Too High in Freq Post by: Jim, W5JO on April 01, 2017, 03:40:05 PM You can measure the crystal with a signal generator, a scope, a 56 K resistor and a 3 Pf. cap. Put the resistor in series with the output of the generator then attach to the crystal. Put the other side of the crystal to the ground side of the signal generator, then attach the 3 Pf. cap to the high side and put your scope probe on that output.
Sweep the generator and look for the null. Parallel resonance is just a bit above the series resonant point. If the crystal won't come on at 100 Kc. you have a bad one, replace it. Title: Re: NC-300 Xtal Marker Too High in Freq Post by: N8ETQ on April 01, 2017, 08:07:29 PM Hey Dick,, Wonder what your AC Mains are at? Those filaments running hotter than a downtown hooker could be the problem. Not just with the calibrator, but also the rest of the rig. GL Please keep us in the loop as u progress. /Dan Title: Re: NC-300 Xtal Marker Too High in Freq Post by: W1KSZ on April 01, 2017, 08:15:24 PM I'll put a Variac on the line and see. My line runs anywhere from 120 to 125 VAC.
So far, not much progress, I posted a want for 100 Kc Xtals, but no response yet. There was a Heath HRA-10-1 Calibrator over on the evil empire, but the last bid was $41+8 for shipping. My Yankee heritage recoils at spending that much or more, especially considering how little I paid for the NC-300 !! 73, Dick, W1KSZ Title: Re: NC-300 Xtal Marker Too High in Freq Post by: Jim, W5JO on April 01, 2017, 08:17:31 PM Check AF4K for the crystal in the HC series holder. He is quite reasonable. ICM sold them for about 25 dollars, but that was before they closed.
Title: Re: NC-300 Xtal Marker Too High in Freq Post by: N8ETQ on April 01, 2017, 08:23:30 PM Hey Dick, Is your addy gud in QRZ? I'll send u a HB 100khz Cal. uses a 2180(?) xtal. runs off 9 V dc. I got one in my 300. use a 33K 2 W "R" in the dc line. Works FB. /Dan Title: Re: NC-300 Xtal Marker Too High in Freq Post by: W1KSZ on April 01, 2017, 10:15:15 PM Address in QRZ.com is correct.
Many thanks for the offer, I'll let you know when it arrives. 73, Dick, W1KSZ Title: Re: NC-300 Xtal Marker Too High in Freq Post by: Carl WA1KPD on April 03, 2017, 08:35:30 AM Got it.
I "assumed" you were talking about compared to 10 MCS WWV. My standard. My bad Carl Title: Re: NC-300 Xtal Marker Too High in Freq Post by: N8ETQ on April 03, 2017, 08:45:40 PM Carl, Could be but the NC-300 doesn't do 10 MC. Too bad, a great RX, just "Challenged" by modern standards. I've had prolly 4 or 5 300's but due to Ham Band only limitation have moved them all along. My only "Ham Band RX only" now is a 75A-4 but still have a 300 in my shop. The NC-400 OTOH was an excellent rig, The 300 really needs a calibrator due to that 2215 LO osc Coil that soaks up humidity and is temp. sens. Even if National Refurbed it to XTAL they fly all over the place. Dick, Had a Family Crisis yesterday, I'll post that Calibrator on my way home from work tomorrow.. /Dan Title: Re: NC-300 Xtal Marker Too High in Freq Post by: W1KSZ on April 03, 2017, 09:16:24 PM Actually, it will receive 10 Mc. Check out Service Bulletin FSN-39.
I can send you a copy if you don't have it. Tnx again for your help, 73, Dick, W1KSZ Title: Re: NC-300 Xtal Marker Too High in Freq Post by: N8ETQ on April 03, 2017, 09:57:16 PM seen it
Title: Re: NC-300 Xtal Marker Too High in Freq Post by: W1KSZ on April 04, 2017, 10:48:17 AM Once I get this NC-300 working, I will try it. Should be useful for netting the Xtal in
the calibrator. Not the most accurate method but will do for 1950's technology !! 73, Dick, W1KSZ Title: Re: NC-300 Xtal Marker Too High in Freq Post by: KU8L on April 06, 2017, 12:29:15 PM Hi Dick:
WHy do you think netting the cal osc to WWV on the air is not accurate? Seems one can get to within a Hz that way +/- Doppler and other effects which bother if you are looking for tenths of Hz. From previous FMTs, I can say that the online reference is the next best thing to a GPSDO /Rubidium standard and the non-ovened cal crystal isn't going to stay that close anyway. Just curious. Curt KU8L Once I get this NC-300 working, I will try it. Should be useful for netting the Xtal in the calibrator. Not the most accurate method but will do for 1950's technology !! 73, Dick, W1KSZ Title: Re: NC-300 Xtal Marker Too High in Freq Post by: W1KSZ on April 06, 2017, 01:46:45 PM You basically answered your question, for precise measurements one does need something more
accurate than the WWV "Off-The-Air" signal. But, as I wrote, it is adequate for 50's technology. My issue is with the Xtal Calibrator I have not even coming close to 100 Kc. If I could tune it on to freq, than I most likely would use WWV to get it "in the ballpark". 73, Dick, W1KSZ Title: Re: NC-300 Xtal Marker Too High in Freq Post by: w4bfs on April 13, 2017, 01:37:04 PM Got it. I "assumed" you were talking about compared to 10 MCS WWV. My standard. My bad Carl you know every time I assumed something in electronics, it would always come back to bite me ... but its ok with me unless due to our pride we try to keep digging trying to cover up a mistake sometimes it goes really deep ... so I guess you might call this Carls bad cavern ... 8) |
