Title: Wire Prices Post by: WA1GFZ on May 07, 2009, 08:14:06 PM Just walked around Home Depot and found the price of wire down. 1000 foot spool of #12 Romex is $160. It went as high as $460. I like #8 solid bare but the price is still kind of high.
Title: Re: Wire Prices Post by: KM1H on May 07, 2009, 09:18:23 PM I hope the black jacketed #12 Copperweld has come down, I priced a 5000' spool 2 years ago and nearly attained room temperature.
Carl KM1H Title: Re: Wire Prices Post by: KB2WIG on May 07, 2009, 09:33:43 PM I hope the black jacketed #12 Copperweld has come down, I priced a 5000' spool 2 years ago and nearly attained room temperature. Carl KM1H So, you were going to experience lividity? .... .. klc Title: Re: Wire Prices Post by: WA1GFZ on May 07, 2009, 09:48:27 PM I think copper will last longer.
Title: Re: Wire Prices Post by: WB2YGF on May 08, 2009, 08:13:08 AM Funny how copper prices are so volatile, while gold hardly moves despite what all those gold investing commercials keep telling us about getting wealthy with gold.
Title: Re: Wire Prices Post by: W9GT on May 08, 2009, 08:37:27 AM I used to buy 500' rolls of # 12 stranded insulated wire (THHN? anyway, the stuff with the really tough insulation) at Home Despot for around $15.00. The last time I checked, it was around $55.00 for the same roll. That stuff makes great antenna wire...cause it doesn't stretch. I hope the prices are coming down again. I heard there were a number of reasons for the spike in copper prices, including such things as a lot of building materials, including wire, were being used to rebuild in areas hit by the hurricanes. Well, perhaps, it has been long enough now that demand has fallen off.
73, Jack, W9GT Title: Re: Wire Prices Post by: Tom WA3KLR on May 08, 2009, 08:52:49 AM Less copper being implanted in Iraq now.
Title: Re: Wire Prices Post by: K1JJ on May 08, 2009, 10:37:27 AM I used to buy 500' rolls of # 12 stranded insulated wire (THHN? anyway, the stuff with the really tough insulation) at Home Despot for around $15.00. The last time I checked, it was around $55.00 for the same roll. That stuff makes great antenna wire...cause it doesn't stretch. 73, Jack, W9GT Yep, that's all I use here for antenna wire. If the span is more demanding, I even use their #10 wire. That PVC covering keeps it shiny inside for the life of the wire, as long as we seal it off on the ends for water seepage. BTW, when putting up inverted vees (about 60 degree apex angle) using that PVC covering, I find the antenna needs to be cut 2.7% shorter than when using flat dipoles and bare wire - to resonant at the EZNec model's suggested lengths . T Title: Re: Wire Prices Post by: Todd, KA1KAQ on May 08, 2009, 11:33:54 AM My understanding was that a lot of the copper, like plywood and drywall, was being consumed by India and China for their building needs when their economies were jumping. Things slowed down all around the world and prices dropped, but eventually it will pick back up. Might be a good idea to check prices and buy whatcha need sometime in the next year or so.
Title: Re: Wire Prices Post by: WA1GFZ on May 08, 2009, 12:10:28 PM let's hope china keeps all its sheetrock
Title: Re: Wire Prices Post by: WB2YGF on May 08, 2009, 12:35:57 PM let's hope china keeps all its sheetrock Yeah, they need it for rebuilding all those schools that fell in the quake.Title: Re: Wire Prices Post by: W1RKW on May 08, 2009, 02:14:26 PM Lowes in Waterford had 500' #12 stranded THHN for less the $50 the last time I checked which was about 2 weeks ago and #14 went for $24.00.
Question: How do you seal the end of the stranded conductor and insulation when the conductor is exposed? How do you know the insulation/conductor end is sealed and water tight and atmospheric tight? Simply gooping sealant on the end doesn't guarantee a seal. The slightest gap and capillary action will suck water up into the casing. What technique do you use to ensure the strands and casing provide a good seal? Does it really matter as long as the solder connection is good? Title: Re: Wire Prices Post by: KM1H on May 08, 2009, 02:21:31 PM I use the #12 jacketed copperweld for long free span Beverage runs. It doesnt stretch or break under rather high tension and the black jacket is fantastic to eliminate precipitation static. Its what the phone companies call rural wire, lasts forever.
For inverted vees and hanging verticals off the tower I used to use #14 bare stranded copperweld but it turns to rust too damn fast; well 15 years is too fast for me anyway. I still have several thousand feet on the reel and Ill try running a Rustoleum soaked rag over it this time around. Never could keep any type of house wire copper from stretching unless I tied it between 2 car bumpers and gave it a pre-stretch first. Carl KM1H Title: Re: Wire Prices Post by: K1JJ on May 08, 2009, 03:08:32 PM The key to keeping stranded copper wire from stretching is to support the center of the span, especially if there is feedline hanging there.
I've had 2el Quads up at 190' on the tower for 8 years in ice and wind cornditions. I would know if it stretched cuz of the SWR and f-b performance. Because there is little strain on the wire and supported in the middle, it hangs tough. Using #10 wire helps too. Bob: For sealing, I just tape it off snugly with overlaps using that 2"? wide black electrical tape - and I sometimes goop it up with RTV too. The RTV is good for maybe 5 years however, and blows off. But I have wire from the 80's that is still shiny inside. I doubt it hurts if it gets water inside and discolored as far as RF and skin effect on 40/75M, but the deterioration can weaken the wire over time, so might as well seal it off. T Title: Re: Wire Prices Post by: Steve - WB3HUZ on May 08, 2009, 03:18:01 PM It's OK if water gets in. You just have to keep the oxygen out. ;D
Title: Re: Wire Prices Post by: KD6VXI on May 08, 2009, 08:00:40 PM It's OK if water gets in. You just have to keep the oxygen out. ;D Lemme run out to audiophool.com and get some OFC (oxygen free copper) then :) --Shane Title: Re: Wire Prices Post by: K1JJ on May 08, 2009, 09:08:52 PM It's OK if water gets in. You just have to keep the oxygen out. ;D Another way of sealing is to keep out two hydrogen atoms for every oxygen atom you let in. Title: Re: Wire Prices Post by: Opcom on May 08, 2009, 10:44:46 PM Military surplus field phone wire apparenly has some steel strands in with the copper and is very strong, but it is designed to be expendable.
Doesn't the insulation on romex type wire mess up the antenna's performance? Title: Re: Wire Prices Post by: N0WEK on May 09, 2009, 01:04:31 AM Lowes in Waterford had 500' #12 stranded THHN for less the $50 the last time I checked which was about 2 weeks ago and #14 went for $24.00. Question: How do you seal the end of the stranded conductor and insulation when the conductor is exposed? How do you know the insulation/conductor end is sealed and water tight and atmospheric tight? Simply gooping sealant on the end doesn't guarantee a seal. The slightest gap and capillary action will suck water up into the casing. What technique do you use to ensure the strands and casing provide a good seal? Does it really matter as long as the solder connection is good? I checked at Home Depot today and 500 ft spools of stranded 12 AWG THHN are down to $40.00. Title: Re: Wire Prices Post by: Opcom on May 09, 2009, 03:10:40 AM those of us hoarding scrap wire are.. still hoarding it.. aluminum scrap is down also. Might as well call the man to come get it and get it over with. They been throwing away half-spools of wire at work. Picked out some thin "blue wire" that circuit board changes are made with, some shielded multiconductor stranded cable, and some thin RG-?? that is 110 Ohms 100% shield and took them to my cube. I can use it at work when I do special little projects.
Title: Re: Wire Prices Post by: K1JJ on May 09, 2009, 11:31:31 AM Whoops - wrong thread... :D Title: Re: Wire Prices Post by: Steve - WB3HUZ on May 09, 2009, 05:09:02 PM Checked at Lowes today. A 500 foot roll of the #14 stuff was only $20!
Lowes in Waterford had 500' #12 stranded THHN for less the $50 the last time I checked which was about 2 weeks ago and #14 went for $24.00. Question: How do you seal the end of the stranded conductor and insulation when the conductor is exposed? How do you know the insulation/conductor end is sealed and water tight and atmospheric tight? Simply gooping sealant on the end doesn't guarantee a seal. The slightest gap and capillary action will suck water up into the casing. What technique do you use to ensure the strands and casing provide a good seal? Does it really matter as long as the solder connection is good? I checked at Home Depot today and 500 ft spools of stranded 12 AWG THHN are down to $40.00. Title: Re: Wire Prices Post by: Opcom on May 10, 2009, 07:31:11 PM Industry overstock due to less construction, or the real price? That's cheep!!
Title: Re: Wire Prices Post by: WA1GFZ on May 10, 2009, 08:15:18 PM I really like #8 solid bare. Still up around $155 for 500 feet. Works great for a 125 foot span. #10 is my choice for feeders. Last time I bought a couple spools of #8 it was $85.
Title: Re: Wire Prices Post by: K5UJ on May 10, 2009, 10:58:18 PM #14 solid copper insulated in those 500' rolls from your favorite local big box store makes great radial wire.
Title: Re: Wire Prices Post by: KM1H on May 11, 2009, 09:07:55 PM #14 solid copper insulated in those 500' rolls from your favorite local big box store makes great radial wire. Maybe if you are only using 4 of them. Ive been using #18 for decades and the more the merrier to share the current. Carl KM1H Title: Re: Wire Prices Post by: k4kyv on May 12, 2009, 02:23:31 AM In 1974 I bought 16,000 ft. of #12 bare soft drawn copper wire for my radial system for $400.
That was during an economic downturn, and I kept watching copper prices until I thought they had bottomed out. A friend of mine's dad owned a wire factory, where they bought the bare wire in bulk and added insulation, fabricating Romex and single strand house wiring. He sold me the bare wire by the pound at his cost. The price of copper seems to pretty well track the state of the economy. My friend told me that his father always thought I must be totally nuts when he found out that I was planning to bury the entire contents of those spools of wire in the ground. For my antennas I use #8 or #10 bare copperweld. Years ago I was given a lifetime supply of the stuff, in addition to what I had already grabbed off the side of the train tracks while they were taking down some of the old open wire telegraph lines. Title: Re: Wire Prices Post by: K5UJ on May 12, 2009, 11:18:57 AM My friend told me that his father always thought I must be totally nuts when he found out that I was planning to bury the entire contents of those spools of wire in the ground. I sometimes imagine what would happen if I sold my house and left the radials. I picture the new owners trying to dig a hole in the back yard, gradually finding the whole lot blanketed with buried copper wire and wondering what kind of crazy nut used to live here. Title: Re: Wire Prices Post by: k4kyv on May 12, 2009, 11:56:57 AM It would be a shame to waste a good radial ground system. But also a lot of work to pull up the wire. I doubt that even when copper prices were high, many copper thieves would go after a buried radial system unless it had been recently laid. I have inadvertently left scraps of wire lying on the ground, and when I would discover it a couple of years later, it would be almost impossible to pull up out of the sod.
Title: Re: Wire Prices Post by: KM1H on May 12, 2009, 09:55:38 PM Bare copper disappears pretty fast in some soils as many BCB stations are finding out during a proof of performance test.
Thats one of the reasons the FCC authorized elevated radials per several requests. Carl KM1H Title: Re: Wire Prices Post by: K5UJ on May 13, 2009, 01:46:42 AM Bare copper disappears pretty fast in some soils as many BCB stations are finding out during a proof of performance test. Thats one of the reasons the FCC authorized elevated radials per several requests. That's interesting. I've heard of that problem with aluminum radials. There have been a few attempts at saving money, one at WOR at one time according to what I've heard, where substituting aluminum for copper turned out to be a bad idea for the reason you gave. Any idea what regions have the anti-copper soil? Thanks, Rob / K5UJ Title: Re: Wire Prices Post by: KM1H on May 13, 2009, 09:52:48 AM Im not a chemist or metallurgist but would guess any acidic or alkaline soil would react with copper. The further away from a neutral PH the more the reaction.
With WOR and many others built on salt marshes the process would be accelerated. Ive opposite conditions, Im pretty much on granite and elevated radials are superior to on ground for me. Carl KM1H Title: Re: Wire Prices Post by: k4kyv on May 13, 2009, 12:22:15 PM The soil in New England is reported to be notorious for corroding away copper radials. Here, they tend to suffer little damage. I seem to recall that acidic soil is bad on copper and that alkaline is bad on aluminium, but I would have to review my chemistry before I would say for sure.
I believe copper is used extensively for boat and ship hardware. It must be one of the more durable metals in a salty environment. Back in the days of open wire telephone and telegraph lines, steel wire was used for most telephone service. However, the telegraph lines along train tracks used copperweld, because the corrosive effect of the sulphur content in the coal smoke from steam locomotives caused solid steel to rust away very quickly. My antennas are made from some of that wire. I have heard stories that in Puerto Rico some AMBC stations have gone to using galvanised barbed wire, which lasts a long time in their soil, to avoid copper theft. Title: Re: Wire Prices Post by: Ed/KB1HYS on May 13, 2009, 05:00:51 PM I think the resistance to corrosion for copper is based on having a coating of copper oxide that seals the metal away from the environment. There are some 100+ yr old buildings in town here,and they have copper roofing flashing, green as grass but still sitting up there. It'll last for ever or until some copper thief gets over his fear of hieghts. AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
Some one was talking about those buildings and remarked how nice they would look if they would polish the copper up... ::) |
