Title: Virtual Strip Chart Recorder? Post by: Bill, KD0HG on December 19, 2011, 07:25:34 PM I am working on a project..I need to do a strip chart recording of a DC voltage over a month period, samples taken and logged once an hour, 24 per day.
Yes, the obvious way to do it is with a real pen recorder, but how would one do this with a modern PC? Some sort of visual exportable format would be necessary. How would one record a DC level? Fire away. Bill Title: Re: Virtual Strip Chart Recorder? Post by: Steve - K4HX on December 19, 2011, 07:58:13 PM Believe it or not, Radio Shack sells a DVM you can connect to a PC via RS232 and log readings. I think the software is no great shakes though. But they are cheap ($40 on Amazon) and the software is a free DL.
http://www.amazon.com/RadioShack-Interface-46-Range-Digital-Multimeter/dp/B005MV15HY http://www.radioshack.com/search/softwareResults.jsp?kw=22-812 A more industrial solution is to use a USB DVM module and some real logging sw. http://www.aktakom.com/products/index.php?SECTION_ID=164&ELEMENT_ID=457 I think Fluke and some of the other DVM manufacturers sell similar except they can be used as a handheld DVM too. Be sure whatever sw you get allows for data storage as a CSV file. Then you can import into Excel or other programs for analysis, plotting, etc. Title: Re: Virtual Strip Chart Recorder? Post by: Opcom on December 19, 2011, 11:17:22 PM logging software that can save as excel or comma-separated is always good for moving the data into charts or presenting it.
Title: Re: Virtual Strip Chart Recorder? Post by: WA1GFZ on December 20, 2011, 10:45:25 AM There is a company that makes this stuff and also records transient events. AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
I bet you can rent the equipment. A place I worked had a wave solder machine that lost its mind every time there was a thunder storm. It needed an isolation transformer and a local ground rod. The sample rate needs to be high enough to catch transients ans smart enough to keep the file size under control. |
