Howdy!
Sometimes when it rains, it comes down in BUCKETS!
This last week I was gifted a couple of major hunks of gear. This one is gonna be
ROUGH tho.
I got hold of a Hallicrafters SX-42 which has been BADLY stored. For Gawd knows
HOW long (10+ years!) the rig has been living, without cabinet, in the loft of an old
dairy barn; it came to light when the barn was about to be demolished!
The GOOD news first... the rig is 99% complete, and I have the proper cabinet for it.
In fact, among the stuff socked away I found TWO of 'em that only need repainting.
Along with the radio I found a carton containing a LOT of NOS tubes for the rig. A
quick pass thru the Hickok 539C smoked out two bad tubes (audio phase splitter and
an IF amplifier).
There are some modifications, but nothing too serious; they're on the rear apron and
don't show. A couple of extra holes drilled (ventilation?), and some connectors have
been changed.
The BAD news... when I pulled the bottom plate I discovered that I was evicting
several generations of field mice! The shop vac removed a large mouse nest in the
power supply / audio area.
Some wiring has been stripped clean of insulation by critter teeth seeking building
materials, but it's not too bad; they got a few single wires, but it doesn't look like
they weren't ambitious enough to attack the wiring harnesses. After getting out the
nesting crud, the underside doesn't look all that bad.
The topside tho... this is where it gets interesting.
ABSOLUTELY FILTHY!!! Besides the usual chassis crud, there's a couple of areas
that have serious rust patches. My biggest concern is the variable caps; the top
cover over them is missing, and they're quite dirty and have a film of corrosion (?) on
the cap plates. Any suggestions on cleaning that up? First thought; take them out
and put the variables thru the dishwasher, primed up with strong detergent and
some ammonia!
As far as the chassis rust is concerned; I'm thinking get it off with a wire brush and go
at the areas with sandpaper and / or Dremmel took to get to bare steel. Once I'm at
that stage replate zinc onto it.
The front panel... not certain yet, but I think a complete refinishing is called for.
Has anyone here had experience with getting a panel silkscreened?
That big, Lowe inspired dial and S-meter are in dirty but usable shape.
Interestingly, the radio doesn't seem to smell of mouse droppings like I'd expected it
to.
There are some parts needed.
Does anyone have a BFO knob? This one is smashed.
Also... the LOCK knob (and shaft???) that is in the center of the main tuning dial
is missing.
The radio is in tough shape, but it's FAR from a parts set, IMHO.
ANY suggestions on getting this old lady up and running would be appreciated!
73's,
Mr. T., W9LBB
