April 20, 2024, 07:24:40 AM *
Author Topic: Valiant VFO mod. & Zener?  (Read 4253 times)
stevef
« on: October 30, 2005, 10:30:28 AM »
I am doing the VFO modification (K6HLO, WB0TOW, etc.) to my Valiant.  Where in the world can I find a 150v, 5w Zener ?
Tnx, Steve KK7UV
n2bc
« Reply #1 on: October 30, 2005, 12:40:57 PM »
Just series a bunch of lower voltage jobs.  I used a string of 1N5357's 20V @ 5W - Seven in series will give you 140V @ 35W, the much higher than needed wattage will keep them stable.
Have fun!  73, Bill  N2BC
K6JEK
RF in the shack
« Reply #2 on: October 30, 2005, 01:36:45 PM »
NTE part NTE5161A
Mouser part 526-NTE5161A
NTE parts are common as dirt so I imagine Newark and Allied have them too.  I've also purchased high voltage Zeners from Surplus Sales of Nebraska.
Jon
Steve W8TOW
« Reply #3 on: November 01, 2005, 09:19:17 AM »
I typically use NTE subs....
gl...remember, if you use the Hammond P-T 124E as a dirver trany,
and either PP or Parallel 12AU7, you must "back" connect it...
vri 73 steve
8tow
73  W8TOW
stevef
« Reply #4 on: November 06, 2005, 06:27:39 AM »
Thanks all, I found a Zener.
Steve, What is wrong with the stock transformer? - or rather, why the need to use the Hammond?
TNX, Steve KK7UV
W3NP
« Reply #5 on: November 06, 2005, 02:10:35 PM »
vri 73 steve
8tow
Steve - what exactly do you mean by "back connect" it?  Reverse the primary and secondary connections? I have seen mention somewhere of this and using a resistive divider on the "New" secondary to apply grid bias.
What is the reason for "back" connecting?
---Dave  W3NP
