May 22, 2025, 03:14:36 AM *
Author Topic: 24 MOSFET class E 80 160 transmitter build looking for Elmer to help  (Read 1515 times)
KD6CXW
« on: January 28, 2025, 06:41:01 AM »
I plan on building a 24 MOSFET PWM 80/160 transmitter.
using a DDS VFO .
Looking for an Elmer to help with build as I am new to the Class E .
I've repaired and built tube amplifiers and worked on and modified tube transmitters .
I have found Steve  WA1QIX web site full off great information .
I've acquired some parts from a person whom decided not to build his transmitter, getting ready to order PWM boards and other parts .
73's
KD6CXW
John
W1DAN
« Reply #1 on: February 02, 2025, 02:58:31 PM »
Hi John:
I've only built a 6-FET PDM rig, but I am happy to attempt to answer questions as I can.
Dan
W1DAN
« Reply #2 on: February 04, 2025, 08:28:43 PM »
Okay, I did not look you up - where are you located?
There are three parts to the build
- parts
- the custom chassis work
- the labor
The 4th one, cost.
How did you decide that "24 Fet" is the right thing for you?
KD6CXW
« Reply #3 on: February 12, 2025, 07:46:40 PM »
to many things going on, hard to find time for projects .
I have been reading Steve's site on AM PWM transmitters and decided  to go from tubes to solid state . Started collecting parts , will need more though . The fabrication is no problem that's what I do for work.
Finding time may take some work.
Need to order boards and parts from Steve then work on the DDS VFO , making sure it acts the way it should and with a touch screen display with options I would like to add.
