July 22, 2026, 09:57:56 AM *
Author Topic: Parasitic Suppressors?  (Read 9041 times)
KD1SH
« on: August 27, 2024, 04:46:56 PM »
  Among the items I came home with from Moxboro this past Saturday was a zip-lock bag of axial-lead inductors wound on resistor cores. The resistors, based on the visible color bands, are 22 ohm, and their dimensions would indicate a probable 5-watt rating; most likely carbon-comp. The coils are seven turns of what measures out to be 18 gauge. My LCR shows 0.3uh. I haven't swept them for a resonant point yet.
  Parasitic suppressors, maybe?
« Reply #1 on: August 29, 2024, 08:25:02 AM »
Just make sure they don't have any Ferrite in them, new chokes all seem to now.
73DG Tongue
KD1SH
« Reply #2 on: August 29, 2024, 09:37:38 AM »
  No ferrite in sight; the resistors appear to be very ordinary carbon-comp types. Still, I won't be trying them in anything big. I've got a couple of low powered transmitter projects envisioned in the near future, so they'll probably wind up in those.
73DG Tongue
ka1bwo
« Reply #3 on: September 18, 2024, 03:04:23 PM »
I had the same question about the plate suppressors using two 100 ohm, 2 watt carbon resistors in my 3-500Z amplifier. Looks like yours will have a lower resonant frequency with more turns.  Model values: C1=285.4f, L1=500n, R1=410.1, R2=.1
W4AMV
« Reply #4 on: September 18, 2024, 07:10:27 PM »
I measured some parasitic chokes that were
used in a homebrew amplifier and they looked
something like this. Shown is S11, reflection
coefficeint from 1 MHz to 200 MHz. Their
response tends to follow a parallel line
with the real axis with increased
frequency and no clear resonance
point. The R component tends to dominate
and that is desirable. This plot from a
model, but close. The curvature really
flattens out and ideal, never crosses
over the real axis to the capacitive side.
ka1bwo
« Reply #5 on: September 18, 2024, 08:53:20 PM »
Hi Alan,
Your S11 plot looks great, you would have crossed the real axis and achieved resonance
 if you swept higher in frequency. Here is the S11 plot of the 3-500Z plate suppressor for your comparison.
ua3ral
« Reply #6 on: November 10, 2024, 07:18:43 AM »
L =6 витков.диаметр намотки 10мм.длинна намотки 15мм ПЭВ-2  1.6мм
R=50 oм . C=68 пф
Yuriy
Когда Маркони собрал радио он услышал голос А. Попова!
I QSY'd to QRZ
« Reply #7 on: November 10, 2024, 12:11:06 PM »
L = 6 turns. winding diameter 10 mm. winding length 15 mm PEV-2 1.6 mm
R=50 ohm. C=68 pf
