April 11, 2026, 04:02:23 AM *
Author Topic: Gates BC1T or 3CX3000 Amp  (Read 4431 times)
w4ax
« on: August 26, 2024, 12:35:18 PM »
It's time to thin the herd a bit.
For Sale Gates BC1T converted to 75M on on the air without issue. Includes a custom vacuum relay time sequencer. 100% new tubes. I'll include two spare 833A tubes. Its all set up and ready to play simply add a +10 VU audio signal, a PTT switch, and a receiver to connect. 240VAC. Includes a heavy duty 240VAC variac if you you'd like to reduce the finals voltage. You can see photos here including my conversion steps. https://photos.app.goo.gl/Psd92JmRvr1jty466 https://w4ami.org/macks-restoration-bc-1t I'm selling it because I primarily use my Collins 20V-3. I am located about 45 miles north of Atlanta. My info is good on QRZ. Email w4ax.mack@gmail.com
Asking $4500 or best reasonable offer. Pick up only where I will demonstrate the operation.
For sale homebrew 3CX3000A7 amplifier. Brand new tube. Power supply greater than 5KV at 1.5A. I have it on the air on 40M presently but it can be moved to other bands as desired. The tube costs $1200 alone and has less than 5 hours filament time on it. Its ready to connect to your transmitter or transceiver. Here are pictures: https://photos.app.goo.gl/qfL4JDMz1XtGii2X8 You be hard pressed to find a better homebrew 3x3 amp. This amp, into a dummy load, will easily produce 5 KW of AM. I'm selling it because I have two other 3CX3 amps. $3800 or best reasonable offer.
Email me at w4ax.mack@gmail.com and we can exchange phone numbers so you can speak with me live and ask any questions. I'll demonstrate everything working normally in my ham shack but once you drive away they are yours. No warranty. I will provide technical advice. Feel free to share this listing with others and other sites.
Mack
W4AX
https://www.qrz.com/db/W4AX
Mack
W4AX
