November 19, 2025, 12:41:23 AM *
Author Topic: Looking for C-454 tank coil info for BC-610  (Read 4918 times)
W9BHI
« on: July 25, 2024, 11:49:26 AM »
I am looking for coil information on the C454 1.5 to 2.0 Mhz tank coil. I need to know the turns count on each side of the main tank and the turn count on the moveable link. I have a C-455 coil which is 1.0 to 1.5Mhz. I will be taking turns off of it to bring it up in frequency to match a C-454.
I posted this in the military section also.
Thanks,
Don W9BHI
n5ama
« Reply #1 on: August 09, 2024, 10:22:58 AM »
I think I have one handy. I’ll check if I do.
Tom N5AMA
n5ama
« Reply #2 on: August 28, 2024, 08:18:59 AM »
Ok, I checked my BC-610 and don’t have the tank coil you are looking for.
Sorry,
Tom n5ama
W9BHI
« Reply #3 on: August 29, 2024, 09:42:11 AM »
I found someone who had one I could look at, thanks.
n5ama
« Reply #4 on: September 01, 2024, 10:49:31 AM »
Ok, I misunderstood what you are looking for. I think I do have the 1.5-2.0 mhz coil and will get you the coil count.
Tom N5AMA
n5ama
« Reply #5 on: September 03, 2024, 08:41:50 PM »
Ok, the turns count if you don’t have it is 23 turns each side and six in the middle. It’s a shame to alter the coil you have. I would think there are more of the 1.5-2.0 and you shouldn’t have to destroy the one you got.
Tom N5AMA
Detroit47
« Reply #6 on: September 03, 2024, 08:54:09 PM »
Couldn't you just short out the extra turs and leave them intact.
n5ama
« Reply #7 on: September 04, 2024, 08:50:47 AM »
I’m sure that would work and if you did this on the lower part of the coil set, it wouldn’t be obvious.
Tom N5AMA
Page created in 0.097 seconds with 18 queries.
