January 13, 2025, 02:30:54 PM *
Author Topic: Filament Choke Kit?  (Read 2949 times)
KD1SH
« on: June 09, 2024, 10:15:14 PM »
  Okay, having a memory lapse, here: some outfit was selling filament choke kits, with which you'd get the ferrite rod, wire, and mounting clamps, but now I can't for the life of me remember who it was. I thought I'd bookmarked the site, but I can't find it. Was it Fair-Rite, or maybe Palomar? I've visited both sites, but so far haven't been able to find it on either.
由obin, in the 1960's Batman TV series.
« Reply #1 on: June 10, 2024, 06:47:00 AM »
Go to W8JI ctr engineering.  Best setup available right now.
Otherwise I get a torrid donut and wind my own.
WP2ASS / ex KD6VXI
W1ITT
« Reply #2 on: June 10, 2024, 08:08:16 AM »
I think it was Amidon who sold the solenoid-wound filament choke kits.  Tom, W8JI, has superior plate chokes as he designs them to avoid resonances in places where they don't belong.
73 de Norm W1ITT
KD1SH
« Reply #3 on: June 10, 2024, 09:33:54 AM »
  Yes, it was Amidon, thank you!  https://www.amidoncorp.com/flc-10-kit/
  I've got an amplifier project in the works that will use a trio of 3-500Z's. The filament chokes I have here in my shop are wound with #10 wire; overkill for using one choke for each tube, but not quite sufficient for using one choke to feed all three tubes (I tested that葉he single choke gets really hot at 45 amps). These kits use #14 wire, which should be fine at the 15 amp filament current of the 3-500Z熔ne choke for each tube.
  I do wish that Amidon would provide specs for the kit on their site, though.
73 de Norm W1ITT
KD1SH
« Reply #4 on: June 10, 2024, 11:59:53 AM »
  I didn't see filament chokes on the CTR site, but maybe I didn't look in the right place. I do know that he's got excellent plate chokes.
WP2ASS / ex KD6VXI
« Reply #5 on: June 11, 2024, 01:50:10 PM »
WP2ASS / ex KD6VXI
Email Tom.  He makes them with a slew of beads now.
VE7RF has also stayed making them but not sure if he just copied Tom or what.
I use a FT240-43 for 40 meters and up, or type 31 for full HF.   I have been able to wind #6 wire on a torrid for 4 X 500Z tubes.
The chokes I've built have VNA sweeps in other threads on this site.
But, email to with what you need and he will get you straight.
WP2ASS / ex KD6VXI
WA5VGO
« Reply #6 on: June 15, 2024, 03:22:32 PM »
If anyone is interested, Surplus Sales of Nebraska still has NOS B&W filament chokes.
Darrell
KD1SH
« Reply #7 on: June 16, 2024, 01:35:37 PM »
   Okay, after talking with Frank, WA1GFZ, about filament choke design, I'm thinking I'll try the ferrite bead approach, sliding 43-mix beads over heavy gauge conductors (45 amps filament current). Heavy conductors, like #4, are a bear to wind around a core; the bead approach is a good solution. Some good info, along with pictures from KL7OF and K1JJ, can be found here: http://amfone.net/Amforum/index.php?topic=48108.0
   Here's a thought: most have been using the single-hole beads, but would the "binocular" cores works as well? I'm thinking about these: https://www.amidoncorp.com/bn-43-7051/
   There would be a mechanical advantage in that the conductors would be kept physically separated, and since ferrite mixes tend to have a very ohmic high resistance, it wouldn't even be necessary to use insulated wire. But my primary question is whether or not the currents in the wire would still cancel, preventing core saturation, as in the case of a standard bifilar rod-wound choke? I should think that they would, since the induced magnetic flux will permeate the entire core whether both conductors are immediately adjacent or not, since they run through the same core.
 AMfone ゥ 2001-2015
