December 07, 2025, 12:48:10 AM *
Author Topic: 75m-40m AM QRO Antenna Recommendation - No Tower  (Read 5293 times)
K1JOS
« on: May 30, 2024, 10:31:16 AM »
I am setting up my first dedicated AM station for 75m and 40m.  I have a Viking 500 almost ready to go live and also buying a SuperSenior 80-40.  For SSB/CW I have a 2kW-ICAS EFHW that has worked very well but would not handle the Viking or SuperSenior.  I do have several 80-90' Black Locust trees near the shack but little room for ground radials.  Any advice would be very much appreciated.
Jerry NY2Kw
KF4NU
« Reply #1 on: May 30, 2024, 06:12:36 PM »
You already have ready made masts there, how about Inverted V's.
73's
Mickey KF4NU
w9jsw
Two shots of Whisky
« Reply #2 on: May 30, 2024, 07:39:32 PM »
An 80/40 fan dipole is what I use. Works perfect. I run a pair of 813s modded by a pair of 813s. Handles the juice just fine. Cut for the AM portion of both bands.
« Reply #3 on: May 31, 2024, 01:50:56 AM »
Thinking outside the box, a steerable tuned loop would magnify your ERP a bit...
K8DI
« Reply #4 on: May 31, 2024, 08:52:35 AM »
I’m similar to John on this with an 80-40-20 fan dipole, hung very slightly inverted V style. The ends are 5’ down. I run the RCA into it with no issues.  That’s a kilowatt plus of carrier converted broadcast transmitter, so, yeah, wire antennas can handle the gas…
Ed
w9jsw
Two shots of Whisky
« Reply #5 on: May 31, 2024, 09:24:29 PM »
Some loop antenna information - https://kk5jy.net/magloop/
KA7WOC
« Reply #6 on: June 01, 2024, 05:27:51 PM »
Full wave loop has worked well for me.  I run open wire into a Kilowatt Matchbox.  Held up by trees.
Bob (aka Boatyard)
WD4DMZ
« Reply #7 on: June 02, 2024, 03:19:47 PM »
For my AM set-up I use an MFJ 80/40 meter dipole. Total length is under 90 feet as a flat dipole. SWR is great for all of 40. Under 2:1 on 80 for about 100 khz, under 3:1 for over 150 khz.
If MFJ still has any in stock the 800 watt version runs under $100.
Inexpensive and easy to set up.
Rich
W8EJO
« Reply #8 on: July 13, 2024, 12:34:47 PM »
This may work for K1JOS with all those tall trees.
80-10 loop.
I recently downloaded the latest (free) version of EZNEC (https://eznec.com/) & have been modeling an 80-10 horizontal loop for my NW Michigan cabin. I have 5 acres & lots of tall trees but no tower. I’ll be heading up soon for an extended stay & wanted a simple multi band wire antenna.
After many tries I finally arrived on an isosceles triangular shaped loop that should cover 80-10 with 50 ohm coax feed (with 4:1 balun @ feed point).
The loop is 274’ in circumference. The base is 80’ & each side is 92’.  Height is 40’.
The SWR 200 is below 2:1 on 40, 20, 15, 12 & 10. It is below 3:1 from 3.6 – 3.8 and 3.3:1 @ 18.1 MHZ.
A 4:1 balun @ the feedpoint should make modern rigs with internal atu’s happy.
Hopefully it actually works as well as EZNEC predicts. I’ll find out next week.
* 80 Hloop plot.pdf (94.8 KB - downloaded 84 times.)
Terry, W8EJO
w9jsw
Two shots of Whisky
« Reply #9 on: July 13, 2024, 09:59:32 PM »
Does the circle on the plot denote the feedpoint?
W8EJO
« Reply #10 on: July 14, 2024, 07:25:17 AM »
Yes.
I tried to attach the EZNEC file but that file type is prohibited.
Terry, W8EJO
« Reply #11 on: July 15, 2024, 09:27:55 AM »
125' flat top, balanced feedline w/ link coupled transmatch.
Page created in 0.052 seconds with 16 queries.
