August 10, 2026, 10:12:41 AM *
Author Topic: Passing a copper grounding strap through the floor  (Read 12236 times)
« on: June 09, 2005, 01:17:53 PM »
A trick I use to get a wide copper strap through the floor, while avoiding cutting a slot, is as follows:
I form a row of holes, whose length is the same as the width of the strap, consisting of 8 to 12 holes drilled through the floor, each just barely large enough to pass a #12 or #10 wire.  I cut the strap at the point where I want to pass it through the floor.  I then solder across  the end of the strap a corresponding number of pieces of wire, long enough to feed through the holes and extend down a couple of inches below.  Once the wires are inserted into the holes,  from the underneath side of the floor, I solder the rest of the copper strap to the lengths of wires poking through the floor, and continue on my way.
This does less damage to the floor than sawing a slot, and it is MUCH easier to do, using a simple electric drill. If the strap feedthrough is ever removed, it is a simple matter to plug the small holes with wood filler.
Page created in 0.187 seconds with 18 queries.
