March 28, 2024, 04:13:39 PM *
Author Topic: Screen Modulation - 6DQ6 or 6146 for best linearity?  (Read 8572 times)
w8khk
« Reply #25 on: September 19, 2022, 02:08:33 PM »
Somewhere in the 1952 issues of CQ is a big write up on the Rothman system.  July 1952 I think.
Also:
https://worldradiohistory.com/hd2/IDX-AUSTRALIA/IDX/Amateur-Radio/50s/Amateur-Radio-AU-1952159.pdf
https://patents.google.com/patent/US2765443A/en
Sounds interesting......
Matt, thanks for sharing.  I discovered those links when the Rothman was previously mentioned.  Will not fit in the T-60 build, but perhaps in the other exciter I am building.  I am not a great fan of the "controlled carrier" sound, but it could prove interesting to play with.
K9MB
« Reply #26 on: September 19, 2022, 04:57:24 PM »
Mike, I just noticed you mentioned you were interested in the Mini CNC.
Attached are a couple pictures, one showing the controller based upon Arduino, to which I added limit switches with optically-isolated interface.
This mill is under $400 via Amazon, and is very solid.   If you are interested in one, I suggest you opt for a build that uses machined aluminum for the structure.  Avoid plastics or 3-D printed brackets at all costs, they just do not hold up or provide accurate positioning with the stresses of the high-speed cutting bits.
That is very interesting and the cost is surprisingly low. Does this mean that I can finally ditch my nibbling tool forever? 😉
I looked on Amazon and they had a bunch of them for sale. Will check them out.
Edit: 09/20/2022 5:07 AM. Removed second part of post. K9MB
« Reply #27 on: September 20, 2022, 01:01:49 AM »
...One of the things I did not like about the T60 is the low B+ voltages and with that the voltage doubler circuit.
One thing that a voltage double has, though- is that one end of the transformer winding goes to ground.
I have never seen a Full Wave Voltage Doubler circuit with one end of the secondary transformer going to ground.
A good FWVD design has the lower end of the secondary transformer going to the center connections of the first set of filter capacitors, and then to a set of series filtering resistors, and then on to another set of filter capacitors, loaded with a set of bleeder resistors.
In fact, when properly designed, one can get at least three voltages: HV,  MV, and LV from a FWVD.
Below is what I use for a transmitter that uses dual 6146 Finals or a sweep tube final such as a 6DQ5.
As for the T-60 final, 90 mA plate current is about nominal.
* Voltage Doubler Full Wave LV and HV PS.pdf (36.51 KB - downloaded 118 times.)
K9MB
« Reply #28 on: September 20, 2022, 06:13:15 AM »
Hi Phil,
Thank you for pointing out the obvious. I appreciate it.  I have no explanation for being an idiot, in this instance, since I knew better if I had been fully conscious…😉🤪
That low voltage winding could theoretically be inserted in series with the bottom of the winding, but given that it is a cheap Import, it might not be able to handle the voltage to ground, so suggestion withdrawn..
73, Mike
« Reply #29 on: September 20, 2022, 11:26:12 PM »
For what it is, the 6DQ6 is probably capable of maxing out the power supply. Look at the peak current to be had for the 6146-like heater current, which is somewhat a measure of reserve emission, not that the average rating should be exceeded. Tons of current with low screen and plate voltages.
Unless you want to put a larger transformer in there or go outboard with the power supply, would I be wrong to say that the 6DQ6 is enough?
Maybe a slight tweak to anode load resistance to take advantage of what the 6DQ6 offers over the 6146 could be in order but that's probably nit picking!
K9MB
« Reply #30 on: September 21, 2022, 11:47:41 AM »
Well, my rocket engine example on a bicycle serves to caution on practical limits set by space and power capabilities. I suspect that a 200vA Antek toroid might be wedged in and give a lot more power, but then the tuning cap would likely arc over. It is really a wide space receiving cap.
A lot of effort would possibly yield a much more powerful transmitter but that would only add about 3dB to the signal level if it was doubled. I must agree that making a better T60 need not extend to making it more powerful. Better keying, a DDS and
Improving the modulator may make it a fun QRP AM rig and also a nice compact CW rig that can help we who ran these transmitters in our youth experience some fun and nostalgia. MB
lu8dam
Only AM activity
« Reply #31 on: September 22, 2022, 08:24:35 PM »
Greetings from Argentina.
Is it convenient for you to use low level modulation on screen for audio tests?
I experienced a single 6DQ6 modulated to reactor by an EL34 (or 6L6). But for 10 watts with another 6DQ6 in class A it can work fine. I have a video of a 6DQ6 transmitter for another transformer modulated 6DQ6 where I did audiofrequency tests, with 12 watts, without linearity problems.
https://youtu.be/QElyW8HPEeM
Since I'm using a pre-emphasis, you can hear some overmodulation in the higher frequencies of the audio, but when I added a compressor that problem lessened.
Greetings to all.
Only AM. Not active in another mode.
Active in 40 meters.
Ham Radio Constructor.
lu8dam
Only AM activity
« Reply #32 on: September 22, 2022, 08:29:10 PM »
And I have a question! Why do you use a modulation percentage greater than 90 or 100% in shortwave? That caught my attention, since due to a question of not obtaining deformations during fading, the modulation percentage does not reach 100%.
K9MB
« Reply #33 on: September 23, 2022, 10:41:36 AM »
Are you talking about distortion in received audio from selective fading?
That phenomenon is endemic to short wave isn’t it?
The only way I know to counter it is by using synchronous detection. That does require sufficient s/n to work, but the distortion can be much reduced I hear.
MB
lu8dam
Only AM activity
« Reply #34 on: September 23, 2022, 12:40:44 PM »
Effectively.
With a lower percentage, this phenomenon is counteracted, as it is audible (without the need for synchronous detection).
The only thing that strikes me is that I see US stations that modulate 125%, a common modulation in Medium Wave. The radio stations that are listened to in Short Wave do not reach 100%.
All this draws my attention because I have never exchanged a talk with radio constructors from other cultures and nationalities.
Sincerely.
LU8DAM
WA4WAX
« Reply #35 on: November 15, 2022, 06:33:03 PM »
Here is a circuit of the Rothman system with some explanations.
Get about 75% modulation, but easy to do.
https://worldradiohistory.com/Archive-DX/QST/50s/QST-1952-01.pdf
w8khk
« Reply #36 on: November 15, 2022, 08:17:10 PM »
Matt, that is an interesting concept, but a bit over the top to fit into the Knight T-60 enclosure.  Thank you, I will file it away for future reference.  I am already pushing the limits with the addition of the DDS VFO and LCD display.  I will be back to that project shortly, but other responsibilities have pre-empted my work on it for a while.
WA4WAX
« Reply #37 on: November 17, 2022, 10:05:49 AM »
Here is a review article from '65.
https://worldradiohistory.com/Archive-DX/73-magazine/73-magazine-1965/73-magazine-09-september-1965.pdf
