20 m propagation has been excellent the last few nights until about midnight.
May 29, 2023, 02:03:55 AM *
Author Topic: 20 m propagation has been excellent the last few nights until about midnight.  (Read 10831 times)
« on: May 17, 2022, 12:42:32 PM »
We need to have more AM activity on 14.325 MHz and above.
« Reply #1 on: May 17, 2022, 01:30:04 PM »
Yes, it's been a while since we had the Monday evening 20m informal net. It was on 14330 +/- at around 6:30pm CST.
It usually took three tall stations spaced around the country to make things work.
It sure seems to me that the upper bands (15-10 in particular) are mostly void of stations when I listen, but 20m and 17m are usually more busy.
I need to dedicate some hardware up there to get on. Moving my daily 75m lashup back and forth is somewhat of a pain.
« Reply #2 on: May 17, 2022, 06:47:22 PM »
Hi Jim,
Yes, having a dedicated 10-20M rig all tuned up for an antenna makes band changing painless.  I'm trying to set up something dedicated here for 20-10M.
I'm curious what the 20M USA tall ships are using for antennas and how high are they?   I'm trying to get a feel for what takeoff angles are important for general USA coverage.  I suspect that antennas too high (10 degree takeoff angles) will not be heard well and probably lower antennas (20-30 degrees TO) would be the better choice.   Of course when it comes to opening and closing the bands for DX, the higher antennas (lowest angles) are best.
I'm also looking into 0/180 degree stacked antenna phase switching to tap those higher angles when needed, but more complex to implement - but may be worth it.  A pair of stacked lazy H's open wire fed for 10-20M is haunting me.  Broad-banded, it would even work on 18 MHz, 24 MHz or 27 MHz with similar gain.  Wouldn't that be a hoot!
« Reply #3 on: May 18, 2022, 06:45:07 PM »
Tom, when the band is good and open, a 100 watt station with a dipole qualifies as a tall Ship so long as the distance is right for a single hop, or maybe two hops.
In the old days, an AM'er with an 807 modulated by 6L6's could work the world on 20m. That changed with the store bought stuff and SSB. An 807 on AM next to a legal limit SSB station (usually clipping on peaks) is no match. So having some extra communication margin is nice to ward off QSB and stations moving in from below or above.
w9jsw
Two shots of Whisky
« Reply #4 on: May 22, 2022, 08:40:47 AM »
Last night was listening on 20M above 14.325, but no AM signals. Would have been a good night. 80M and 40M was totally dead due to static crashes and high noise. 20M was fairly calm.
« Reply #5 on: June 20, 2022, 09:52:48 PM »
I have crystals for 14.286, 14.320, 14.330, and 14.40 MHz for my Tube rigs.
For any other frequency, I have to use my Icom-7200.
It's unfortunate we don't don't have a "SKED" Message Center or Forum here.
Phil
N4DJ
« Reply #6 on: January 25, 2023, 03:32:16 PM »
I have been listening on 20 off and on around 14,286 and 14,330 but not hearing any activity.
Only thing lately is some activity on 29,000.
