April 25, 2024, 02:04:07 AM *
Author Topic: RG-6 AS TRANSMISSION LINE  (Read 9723 times)
« on: March 03, 2021, 02:18:57 PM »
Have you ever used RG-6 as a transmission cable and if so, what power level, frequency and length did you use and your results?It looks like it could handle descent power but I wonder how it would work at 500 feet on 160-40 meters
Thanks Terry
Attached is a power chart comparing RG-6 with other cables.
https://owenduffy.net/transmissionline/RG6/index.htm
kc9pcp
« Reply #1 on: March 04, 2021, 11:00:18 AM »
I use 50ft of RG-6 regular ATV cable for my FT-450 for connecting to my 20m to 6m  fan dipole and it works good. Of course this is only max 100 watts.
Also it has to be RG-6 or 72 ohm cable all the way. Using a 50 ohm cable to the the ground block and then 72 ohm RG-6 would not work with the autotuner.
Linas KC9PCP
Tom WA3KLR
« Reply #2 on: March 04, 2021, 12:09:32 PM »
Hi Terry,
RG-6 was engineered for TV service 50 - 500 MHz. Amazingly low loss for its size. The copper-clad steel center conductor serves as the center pin in the F connector.
I don't have any practical experience with RG-6 on HF transmission. BUT, for 160 meters I would go with the solid copper center conductor. This is mentioned in the link of yours, a good reference.  The loss curves at the top of the article are computed based on one loss reference point and does not show the actual loss with the copper-clad steel conductor at 2 MHz. The actual loss will be higher since the current now is forced below the skin depth of the copper clad and steel has more resistance plus it is a high permeability material with high skin effect.
WB3JOK
« Reply #3 on: March 14, 2021, 06:50:38 PM »
I run about 40-50 feet of RG-6 to my OCF Windom antenna (with a 4:1 balun at the feedpoint). I'm primarily interested in 80 and 40 meters and it seems to work quite well there.
« Reply #4 on: March 16, 2021, 04:35:52 PM »
Thanks Guys! What type of connectors do you use on the RG-6? I have heard that there are adapters to go from the RG-6 connector to BNC? I haven't done any research on connectors as yet so anything suggested would be helpful!
There doesn't seem to be a lot of use for this cable with hams but for the price and with moderate power levels, how can you go wrong?
tnx
Terry
N4LTA
« Reply #5 on: March 16, 2021, 05:07:46 PM »
75 ohm BNC crimp on connectors are readily available for RG6. Lowes has them as standard items.
ka1bwo
« Reply #6 on: March 21, 2021, 04:38:43 AM »
Thanks Terry
Hi Terry,
I miss your witt talking to you on the air. What impedance is transmission line terminated into, 70 ohm at resonance or Z vs frequency across the band. What worse case length of RG6 are you going use? I don't assume anything. I can post a (S21) insertion loss plot vs frequency.
Joe
ka1bwo
« Reply #7 on: March 21, 2021, 11:28:43 PM »
Thanks Terry
100 feet of RG6U belden 7915A, first plot: insertion loss vs frequency  terminated into 50 ohms, 2nd plot:  terminated into 75 ohms. Source impedance in both cases is 50 ohms.
« Reply #8 on: March 22, 2021, 08:50:32 PM »
Hello Joe & all, thanks for your response. The xly on this end is suffering from dementia so that and the fact that I ain't getting any younger adds to my slow response in getting back to a thread. Yes, I miss talking with everyone on the radio but in a few weeks I should be on at least a few times each month till cold weather shows up again:(
Well Joe, I have been thinking about buying a new SSB rig maybe a 7300 and I'm leaning toward 17 meters and above perhaps with a fan dipole. I also found out that BNC connectors are expensive along with a quality crimping tool to go along with the setup. I wonder if you Joe have any suggestions about an antenna for 17 and up? I also wonder  how much strain the weight of the cable might impose on a crimp style connector? The antenna would be up about 80 feet between two pine trees or whatever tall tree fits the bill at my camp. I wonder if RG-6 would work as a Bazooka antenna? I used to work the world on 100 watts on 17 meters so that is about what I expect that I will do. Any thoughts?
tnx Terry
ka1bwo
« Reply #9 on: March 23, 2021, 05:10:21 PM »
tnx Terry
Terry,
I'm very sorry to hear about your wife's situation.  When I worked at Raytheon we had a amatuer club station at the plant. The antenna that we used was a fanned dipole it worked really well. The only problem mechanically construction is a bit challenging. The other antenna I would recommend is a doublet it pretty simple, effective and efficient. For matching I use a linked coupled network, Johnson flashbox.  What type coax are you going to use with a crimped bnc connector?  Never built a bazooka antenna hope others have and comment. Here is one more scenario using 100 feet of RG-6 feeding a 40 meter dipole, 65.5 feet long, #12 wire, height of 30 feet . Plot: showing coax loss
Joe
« Reply #10 on: March 23, 2021, 06:35:52 PM »
Joe, the crimped connectors BNC would be for the RG-6 since you cannot solder to the foil. I haven't looked at all RG-6 cables but maybe one of them has a woven copper cable bedded in the jack/foil area? If that type of cable is mfg. then it could be soldered. The whole thought with RG-6 is that cable is really cheap and light weight. Four connectors are about ten dollars and a real good crimp-er is about 85 bucks. So for me to spend that kind of money for a chimp-er I think I'd better talk to a couple of nearby hamboners and see if they want to experiment with some RG-6? I think it may be a hard sell and I'll end up buying what ever is needed to try out this cable.
I am not an engineer and the one thing that stood out to me was a statement the gentlemen said about RG-6 and that was from memory Make no assumptions about its velocity factor, measure it for length critical applications. I don't know what he meant because he did not explain that? Is cable with the lowest number the best? Is it when you choose a certain length that things would go wrong?
Thanks for the 40 meter data Joe.
Terry
« Reply #11 on: March 23, 2021, 07:04:16 PM »
There is an IDEAL brand crimper that crimps both F and BNC.  I can't recall the model and uts buried in packed boxes but I got it at depot or Lowes for a lot less than 80 bucks, that's for sure.
Couldn't tell you how many crimps I did with it, but works great.
ka1bwo
« Reply #12 on: March 24, 2021, 02:13:31 AM »
Terry
Terry,
I didn't realize that RG-6 OD is only .015" smaller than RG-58. I bought a crimping tool for bnc connector on line for $35 to make up cables using RG-58 it works great. That crimper should work for RG-6 too. It must be the same one that Shane has.  I'll check the brand and model #and post . Don't sweat the cable VF.  If the VF=1 the wave will propagate along the line at the speed of light (V), if the VF=.5 the wave will propagate along the line at .5 the speed of light.
 Wavelength =(V)(VF)/frequency.   Physical length of a wavelength of line with VF=1 is twice as long compared to a cable with a VF=.5 at a given frequency.    https://catalog.belden.com/techdata/EN/7915A_techdata.pdf
Forgot to post 40 meter dipole feed point impedance presented to 100 feet of RG-6.
Joe
* 40M feedZ - Copy.txt (1.08 KB - downloaded 154 times.)
« Reply #13 on: March 24, 2021, 08:06:24 AM »
Hi Terry......... he means if you're gonna use it for stuff like phasing lines you'll need to determine the VF or cut for a VF of 1 then trim as needed.
« Reply #14 on: March 24, 2021, 10:39:44 AM »
Was thinking wow I have a few spools of that! But no, upon re-inspection it's RG-59.
Not going off topic but in case anyone else was thinking about a spool RG-59 in their garage for transmission line, it's worth adding that RG-59 doesn't stack up well against RG-6. Don't do it.
« Reply #15 on: March 24, 2021, 09:13:15 PM »
Hello Joe, the crimper that I saw at Loews would crimp on RG-6, RG-59 and two others but I forgot what they were?
Thanks Budly about the V factor. I remember when Tina W1IA was crunching numbers for his phased array that I think was TV hard line. He got it to work but I don't know if it is still up in the air as it came down once before if memory serves me correctly?
I am going to go out 500 feet with the RG-6 just to see how it works. I also have some RF ammeters and some big ass non inductive resistors, that I could put on at the other end and get an idea how much RF is making the trip, to the other end?
Tom WA3KLR
« Reply #16 on: March 24, 2021, 10:23:20 PM »
Hi Terry,
You can measure the loss from one end of the coax with the MFJ-259x or similar gadgegators in 'coax loss' mode, far end of coax is open.  Just move the test frequency around some to make sure you are not parked on a resonant frequency; look for the indicated loss number to be consistent in a range of frequency in your region of interest.
ka1bwo
« Reply #17 on: March 25, 2021, 02:00:33 AM »
Hi Terry,
What  terminating resistor value or values are you going to use at end of the line? Here are few plots. Plot 1: 500 feet of RG-6 terminated into 50 ohms, transmitter output=100 watts , Power delivered to the load vs frequency. 2nd plot: Total power loss, db vs frequency. The line losses is a combination of transmission line insertion loss and standing wave.
« Reply #18 on: March 25, 2021, 02:04:17 PM »
Well Joe the resistors in series and parallel would come out to about 83 ohms so it would be high at about 8 ohms.
Ok Tom, on the gadget, I have one of those things and I'll give it a try. I guess I could put a 500 watt flood lamp on it and look out into the woods for a glow Cheesy Cheesy Would it make a difference if it was still coiled up on the roll rather than payed out to test it?
ka1bwo
« Reply #19 on: March 25, 2021, 03:22:50 PM »
Terry,
If you can get to the end leave it on the roll.  Plots for 83 ohm load, 500 feet of RG-6. Plot1: Power delivered to load vs freq for 100 watt transmitter output. Plot 2: Loss db vs freq.
KW4DE
« Reply #20 on: January 04, 2023, 09:33:00 PM »
I’ve been using solid copper center rg-6 for 160 meter dipole feed for about a year.  I run 800 watts ssb with no problem but the antenna has a 1:1 swr at the operating frequency.
I recommend it, especially for cheap long runs at lower frequencies at modest power levels.
KW4DE
« Reply #21 on: January 06, 2023, 01:07:33 PM »
Hello Darrell, glad to see that the RG-6 is working for you!
73  Terry
WA2IXP
« Reply #22 on: January 23, 2023, 09:27:40 AM »
I've used RG-6 for a 40 mtr dipole for years. Works fine. Have several runs of CATV hardline Some measures about 7/8" od some about 5/8 ". Shack to house and tower to shack. about 300 ft total. A bit of plumbing Enginuity for connectors or spliced to smaller cable taped up. A bit of swr depending on each particular length/band in use. but 1.5 or less.   6 or 2 mtrs  would be another story.  I use regular coax connectors on rg-6 with foil/braid folded over. sometimes a dab of al/cu corrosion stuff if outside. Use what you have,
                                                         Jay
Page created in 0.099 seconds with 18 queries.
