April 20, 2024, 06:29:16 AM *
Author Topic: Collins 70H3 PTO > VFO?  (Read 2572 times)
Carl WA1KPD
« on: December 09, 2020, 02:04:04 PM »
I recently acquired one of these and would like to make it into a VFO to feed 6AG7s and the like.
Google has not been much help. Has anyone done this?
TIA
« Reply #1 on: December 09, 2020, 07:07:21 PM »
I thought the PTO was self contained - i.e. you supply the necessary voltages and it puts out a signal from 1.5 to 3.0 MHz. You need to develop a frequency readout and possibly a mixer to take the PTO signal to a frequency range useful in the ham bands. Obviously, for 160 meters, it's good to go as is except for frequency readout.
KB5MD
« Reply #2 on: December 10, 2020, 12:50:53 PM »
I use one with a 6L6 doubler circuit to drive a Gates BCI-T on 75.  The filaments in the pto are in series.  I rewired them for 6.3 volt operation. It works really well, very stable.  For a frequency readout, a pickup wire near the output coil feeds a digital freq. counter.
Carl WA1KPD
« Reply #3 on: December 10, 2020, 01:01:39 PM »
Roy,
Thank you
I assume you feed the output after the 100pf cap diretl to the grid of the 6L6.
Did you hook up the 28 VDC for the oven?
KB5MD
« Reply #4 on: December 16, 2020, 02:45:51 PM »
The output fed to 6L6.  Did not connect the oven. The output of the 6L6 goes to a 6146 amp stage then to the Gates rf  driver tubes.
