April 20, 2024, 08:30:27 AM *
Author Topic: Why is the winding shorted on all of these balun schematics?  (Read 2468 times)
« on: December 06, 2020, 10:20:36 PM »
These are the common 75 Ohm coaxial -to - 300 Ohm unbalanced matching devices that are (or were) used with TV sets, FM receivers, and any other purpose.
Just about every schematic of these shows one of the windings to be shorted, that is grounded at both ends.
I do not understand why this is good or correct. Anyone know about this mystery?
hundreds are shown this way
https://www.google.com/search?q=schematic+of+a+75+to+300+Ohm+TV+set+balun&source=lnms&tbm=isch&sa=X&ved=2ahUKEwiX1-3L9LrtAhVEcq0KHcz6C1UQ_AUoAXoECBAQAw&biw=1920&bih=919
« Reply #1 on: December 07, 2020, 08:34:06 AM »
http://www.ham-radio.com/k6sti/balun.htm
Scroll down about 2/3 of the way. you'll see some of the same schematics for 75 to 300 ohm baluns and explanation for the short or no short.
Home of GORT. A buddy of mine named the 813 rig GORT.
His fear was when I turned it on for the first time life on earth would come to a stand still.
ka1bwo
« Reply #2 on: December 10, 2020, 03:22:34 PM »
Pat the schematics are incorrect. Were the transformers are connected in series should not go to ground
« Reply #3 on: December 10, 2020, 09:06:30 PM »
These transformers are based on "Transmission Line Transformer" theory.
http://k5tra.net/tech%20library/RF%20transformers/Transmission-Line%20Transformers.pdf
http://www.introni.it/pdf/Amidon%20-%20Transmission%20Line%20Transformers%20Handbook.pdf
https://highfrequencyelectronics.com/Jan06/HFE0106_TraskPart2.pdf
https://www.markimicrowave.com/assets/appnotes/balun_basics_primer.pdf
https://www.amazon.com/Transmission-Line-Transformers-Jerry-Sevick/dp/1884932185
Phil
« Reply #4 on: December 11, 2020, 12:33:47 PM »
Thank you all, I had not given these little baluns much thought though I had opened many.
