April 24, 2024, 01:03:37 PM *
Author Topic: SZIKLAI complimentary-symmetry modulator , ammended  (Read 9506 times)
« Reply #25 on: September 18, 2020, 08:49:23 PM »
As a class a series mod, you're going to get 50 pct voltage swing on the device being modulated....  Using a standard darlington that's the best I could do.
Maybe this configuration will do better, but..
km6sn
« Reply #26 on: September 18, 2020, 10:34:51 PM »
Shane,
Not sure I am following what you are saying. Take a look at the files associated with post #22..
getting full swing on the load.
Rod
« Reply #27 on: September 18, 2020, 10:52:42 PM »
What I am saying is:
With an non / non darlington pair, I can only get 1/2 Vcc swing under real world conditions.  As has been discussed elsewhere (recently) in the qso section.
If the non / pnp darlington pair gets actual near full Vcc swing then this is amazing!
I don't always trust modeling.  Not saying it won't work, I really hope you get near full Vcc swing.
In a series mod with 2N2222 and MJE3055 I see half Vcc swing.
Because of this inefficiency I went PWM.
W4AMV
« Reply #28 on: September 19, 2020, 12:21:57 AM »
Excellent point Shane.
Rod,
One item I believe is missing from the simulation is associated with the AC source.
There is no source R attached. Or I do not see one in the screen shot. Rs is zero. It is set up as an ideal source. Although the input R for the device pair is high, there will be an input signal voltage divider. The consequence is reduced output swing. Re check that aspect.
Attached with sweeps on Rs from 1 to 100 ohms with a step through 50 ohms. You can see the consequence.
Alan
km6sn
« Reply #29 on: September 19, 2020, 07:30:13 AM »
Yes, Alan, I agree. One needs to adjust the driving voltage to compensate for driving source resistance.
I believe Shane is talking about something else.
Shane, could you post your 2n2222/MJE circuit, showing the RF deck equivalent resistance (Vdd/Idd)?
Thanks,
Rod
W4AMV
« Reply #30 on: September 19, 2020, 01:12:16 PM »
Cool....
I built the experiment. All total, 5 minutes. See attached.
No curve tracer matching but required careful setting of bias control.
The Vcc is set at 24 V, the swing is 24 V. Now I confess, I do not have a fancy 6 digit readout scope... So counting scales on my Tek scope. But indeed, careful set the bias and supply is swung, 0-to 24 V. I'll try to post an ugly board pix and scope shot.
Initially setup was no bias tweak. In that case, I lost 4 V in swing. So yes, careful device selection or bias adjustment would be required to get complete swing. The voltage gain for this arrangement is 0.89.
The scope at 5 V/major div. The channel 2 set to 24 V top line. Bottom gnd.
The ugly card is it at 1 kHz. Yep... ugly.
Alan
km6sn
« Reply #31 on: September 19, 2020, 02:12:31 PM »
Alan, good job! Ugly is the way to fly!
Rod
km6sn
« Reply #32 on: September 20, 2020, 09:52:18 AM »
Here is the final version, showing circuit, Vswing, Vfft.  See attached files.
