WA2SQQ
Offline
« on: July 01, 2020, 11:15:02 AM » |
It's a long shot, but no harm in asking Just discovered that my 160W VHF amp has a bad driver transistor. RF Parts no longer carries it and MFJ who purchased Mirage says its "too old". EBAY has a few listed, but all from China. and likely to be knock-offs. Anyone happen to have an MRF240A in their parts box, or know of any place that has one?
Offline
« Reply #1 on: July 01, 2020, 02:59:19 PM » |
WA2SQQ
Offline
« Reply #2 on: July 01, 2020, 07:08:57 PM » |
I called Mouser before posting. They told me it’s a “240”, not the “A” version. Going to call them back and ask about what’s on your web page. Thanks
KF7WWW
Offline
« Reply #3 on: July 01, 2020, 08:58:00 PM » |
What does the A suffix designate? Looks like a typical flange mount transistor. I know some of the A suffix’s designated stud mount type. Are the data sheets incomplete that I found? I have a bunch of Motorola repeater amp transistors in the shop. I’ll see what I have tomorrow.
WA2SQQ
Offline
« Reply #4 on: July 02, 2020, 07:59:09 PM » |
Thanks I’m going to see if I can get both spec sheets to compare. The 240s seem to be available but the A version isn’t.
Offline
« Reply #5 on: July 02, 2020, 08:48:16 PM » |
The 240 is a stud mount, the A is not.
Odd, as that's backwards of most Motorola numbering.
--Shane KD6VXI
KF7WWW
Offline
« Reply #6 on: July 03, 2020, 12:00:52 AM » |
I have some “ house numbered “ devices that may be the part your looking for... I’ll get some pictures tomorrow.
WA2SQQ
Offline
« Reply #7 on: July 03, 2020, 11:46:36 AM » |
Thanks. Are these 240a or an equivalent device?
KF7WWW
Offline
« Reply #8 on: July 04, 2020, 12:53:09 PM » |
The parts I have are the m1132, m1133, m1134. From the micor series repeaters.. I think that the 1134 is the same as the mrf240. Maybe someone else can confirm that?
WA2SQQ
Offline
« Reply #9 on: July 04, 2020, 04:16:48 PM » |
Let me see if I can find some info. I’m sure there are other devices that could be adapted, but I do t have the expertise to start modifying the design to use another device.
WA2SQQ
Offline
« Reply #10 on: July 04, 2020, 07:13:54 PM » |
I called them- been back ordered, with no estimated delivery.
W1NB
Offline
« Reply #11 on: July 04, 2020, 08:04:40 PM » |
FWIW, there are several MRF-240As available on eBay.
Offline
« Reply #12 on: July 05, 2020, 12:34:21 AM » |
See initial post. Thinks it might be a Chinese knockoff. I'd pick one of these vendors that offers free shipping, returns, good feedback rating, and is a long time ebay member. If doesn't work or makes the smoke rise, you always have the option to take your frustration to ebay and/or paypal.
WA2SQQ
Offline
« Reply #13 on: July 06, 2020, 08:56:51 AM » |
Not going to even consider EBAY. Too many counterfeit devices, and the time required to change the part is not worth the frustration. Tried to research the Motorola devices mentioned earlier but found several mentions that spec sheets area seldom available. I have one other idea that I’ll be following up on today. If it pans out I’ll share the plan.
Detroit47
Offline
« Reply #14 on: July 06, 2020, 01:10:04 PM » |
Her is the spec sheet if you want the curves say so.
John N8QPC
Detroit47
Offline
« Reply #15 on: July 06, 2020, 01:11:00 PM » |
more
Offline
« Reply #16 on: July 06, 2020, 01:27:00 PM » |
Not sure where you're looking for spec sheets, but a quick Google found the Motorola stuff: https://www.datasheets360.com/pdf/3640766398462686885
WA2SQQ
Offline
« Reply #17 on: July 06, 2020, 09:37:39 PM » |
These I have.i was looking for the house numbered devices - m1134 Saw several posts that Motorola did not release spec sheets
Offline
« Reply #18 on: July 06, 2020, 11:44:33 PM » |
Not sure why they would. House numbered devices can generally be procured only from the house that labeled them. i.e. "keep your customers close"
