Still today, many "old-timers" poo-poo
coax in favor of twin lead, crappy brown ladder line, homemade
openwire line, boiling wood spacers in wax etc...
Yep.
Whenever I hear someone say coax sucks compared to open
wire, I just remind them that the loudest signals/stations on
the band here in the NE run coax/heliax. Just axe Chuck/K1KW,
Steve/WA1QIX, Gary/INR. Bill/GF, Tina/IA, Bob/KBW, Mike/ZE,
and theres many others. [I run all Heliax or coax, but still can't
compete with those guys... sigh...
Openwire is FB as well as coax. There are advanatges and
disadvantages, but it's not on-air performance.
Personally, I like openwire for connecting together a many
element phased array, esp if the eles are full wave center
fed like lazy H's, etc. Also, even connecting together standard
Yagis is OK wid openwire if it's easier than using coax with
many connectors and matching lines. Right now I'm building
a twelve Yagi array consisting of 2el beams for 6M. It's so
simple to use a T match at each Yagi to bring it up to 200
ohms and feed them directly with 200 ohm, 1/2" spaced open
wire. Just space the Yagis 1/2 wave apart and flip the connections
at each Yagi. In contrast, it would take about 700' of coax and
60 connectors to do the same job with matching sections, etc.
No contest.
But for regular 50 ohm antennas, nothing beats running a
single BIG 7/8" or 1 1/4" Heliax underground to the tower
and using a remote controlled antenna relay system to select
the various antennas.
The loss of openwire in the REAL world works out to be about
the same as 1 1/4" heliax when both are matched. This is
based on actual measurements on 432 mhz and makes openwire
about 20% more lossy than the charts say. Your mileage may
vary on HF due to less skin effect, etc..
There's TONS of surplus/scrap Heliax available now with all the
tower changes going on. It's cheaper to buy than coax if you find
the right sources.
