March 29, 2024, 02:29:46 AM *
Author Topic: Questions on Triode 3C24 plate modulated transmitter  (Read 1769 times)
N4LTA
« on: June 22, 2020, 12:03:12 PM »
I am planning either a single or parallel 3C24 plate modulated transmitter running between 800 and 1000 volts.
I know it will have to be neutralized and I can't find much data for a pi net output with neutralization.
Any typical circuits out there?
Pat
N4LTA
« Reply #1 on: June 22, 2020, 12:10:39 PM »
Checkout the neutralization setup on Tom's 813 pi-network output rig. The pickup plate is top left of the left side 813.
http://amwindow.org/tech/htm/813/813.htm
N4LTA
« Reply #2 on: June 22, 2020, 08:06:37 PM »
It looks like it will take close to 6 watts to drive two tubes. I am thinking a crystal oscillator/VFO buffer and then a 5763 driver. Looking for a typical circuit for a driver for the two 3C24s.
Pi net or inductive coupling? I assume it will have to be tuned, but untuned would be better. This will be an 80 meter only rig.
Pat
N4LTA
KC4VWU
« Reply #3 on: June 23, 2020, 09:49:47 AM »
5763 osc/buffer, 5763 amp, 3c24 PA. If only for 80/75 tuned coupling would be better to reduce harmonic content?
« Reply #4 on: June 23, 2020, 12:26:16 PM »
Pat,
    Take a look at this transmitter built by WZ5Q:
https://forums.qrz.com/index.php?threads/the-evolution-of-a-lonely-af-67.571414/
Might consider beefing up the driver to a 2E26.
I attach Mike's schematic here.
Wd5JKO
