April 16, 2024, 05:23:07 PM *
Author Topic: Help with a Heathkit SB101 power supply  (Read 2423 times)
K8DI
« on: March 05, 2020, 04:59:42 PM »
I picked up a Heathkit SB101 and it’s external power supply last week. The supply rattled.... as you can see in the photo, a resistor was blown up and one half was loose. I cannot tell exactly where it’s supposed to be. There’s not an obvious ‘place it was’ mark nearby. I suspect it was to a ground lug on the capacitor (other caps have paralleled bleeders). Anyone know for sure?
KK4YY
« Reply #1 on: March 05, 2020, 05:26:42 PM »
Lookup the schematic of your power supply here:
https://www.vintage-radio.info/heathkit/
K8DI
« Reply #2 on: March 05, 2020, 05:53:27 PM »
Thanks for the link!  Found the schematic, verified it is a bleeder that goes to chassis.  Now to replace that, add a fuse holder, and a grounded power cord. If I can find room inside the chassis, a relay and separate power supply for it instead of running 120vac to the radio power switch, as well.  Then I will see if the radio itself is parts or a restoration....
Thanks,
Ed
KK4YY
« Reply #3 on: March 05, 2020, 07:34:21 PM »
Ed,
The resistors that didn't burn up may have drifted in value. Best to check them, at the very least. Those 2 watt carbon composition resistors are dissipating almost 1.7 watts each. This might be a good time to replace them all with 5 watt metal oxide film resistors (or better).
Those Heathkit power supplies are still in good demand. I bought a couple of their DC to DC supplies. With new caps and diodes they're as good as new.
K8DI
« Reply #4 on: March 05, 2020, 08:25:02 PM »
I'm sure they have. Caps are probably dried out too... But first I'm going to see if the radio is restoration-worthy before I fully rebuild the power supply...I only need it to nominally work enough to bring the radio up on a variac to get some idea of its condition.
Ed
nq5t
« Reply #5 on: March 05, 2020, 08:48:14 PM »
Ed
You should probably consider one of these.   Easier than trying to do a one-piece at a time upgrade.  Excellent product …..https://www.theheathkitshop.com/page16/index.html
