I modified the active LPF (Q9 on the AF unit) in a Kenwood TS-711A all-mode 2M xcvr to open up the FM transmit audio response. Changing a few components on the PCB and using a good mic was all it took. Instead of cutting off at 3khz it now has a rising characteristic from 1khz out to 6khz then rolls-off. A few fat coupling caps brought up the bass response. It sounds much better now... at least on simplex, which I prefer.
Not having LTspice, I used an online active filter calculator and iterated values until I got what I was looking for.
http://sim.okawa-denshi.jp/en/OPseikiLowkeisan.htmDon
