May 22, 2025, 03:20:28 AM *
Author Topic: Collins 75A2 Band Selector Alignment  (Read 4014 times)
Carl WA1KPD
« on: January 01, 2020, 07:16:44 PM »
My 75A2 band selector drum was way off alignment- It was in the blank area of the dial and would not move with the switch.
Opening it up, I discovered that the string/fishing wire had slipped of the drum on the bandswitch. I replaced it and now the entire thing is out by about ½ a band. Do I adjust it with the set screw on the bandswitch pully, or the setscrews on the drum (hidden I think by a large spiral spring).
The manual is mute on the issue and a Google search did not help.
TIA
« Reply #1 on: January 02, 2020, 10:19:47 PM »
Setscrew on the drum is what I have done...
iirc, there is a section on stringing the front panel dial cord in the manual, but I don't know
exactly what it says or calls for.
MikeKE0ZUinkcmo
« Reply #2 on: January 02, 2020, 10:58:14 PM »
What He said.
Mike KE0ZU
Carl WA1KPD
« Reply #3 on: January 03, 2020, 01:28:32 AM »
Thank you both!
Page created in 0.163 seconds with 18 queries.
