April 23, 2024, 02:50:19 PM *
Author Topic: Can anyone provide specs for this choke??  (Read 2101 times)
K8DI
« on: October 29, 2019, 08:44:06 AM »
Westinghouse reactor, 12Hy, 126 ohms, 240 mA  with the codes L-303594 and CTR-30187. Wondering about voltage rating...
I need a choke input filter for the 866 rectifiers I want to use, anyone have any idea if this thing will live at 2-3 kV?  I have a 1900-1500-0-1500-1900 transformer I want to use, would you risk it??  The choke will be mounted with the frame grounded to the chassis/earth/electrical safety ground.
WA4WAX
« Reply #1 on: October 29, 2019, 01:14:23 PM »
Can you put it in series with the common lead instead of the HV lead?  If so, problem solved.  It will filter just as well.
You might also resonate it at 120 Hz by putting a cap across the leads.  Less ripple.
« Reply #2 on: October 29, 2019, 04:58:00 PM »
does the frame have to be grounded?  If not, isolate it with some insulating material.
Home of GORT.
K8DI
« Reply #3 on: October 29, 2019, 05:05:23 PM »
I’m my world, all large metal objects are at dc ground. It’s a safety issue I refuse to compromise on.
Ed
« Reply #4 on: October 30, 2019, 12:39:13 AM »
Look at the insulators on it, there is your answer.  HV all you want.
(I have an identical unit, was working @ 3kV.
