April 13, 2026, 03:47:03 AM *
Author Topic: Drake L4B summertime project  (Read 11031 times)
w9jsw
Two shots of Whisky
« on: August 11, 2019, 08:43:01 AM »
A year ago I bought a rather rough looking Drake L4B at a hamfest. It was without PS but had 2 3-500 tubes with globes. It seemed relatively intact and unmolested except for some rust on the cabinet from sitting in a humid midwest garage for a number of years. I gave 2 Benjamins for it. I thought the tubes were at least worth it. I had planned to remove the tank and use it for an AM transmitter.
Well I just could not do it. I did not want to tear it apart. I had the tubes tested in a known good amp and found out one is just fine and one is gassy. So not a good of a find as I thought -  Undecided
The power supplies for these are hard to find and expensive when you do find one. I could easily drop 4 Benjamins or more. So it sat.
This spring I started helping a guy make some PCBs. He said he could take that amp and get it working well with a PS he had. So I shipped it to him and he fixed it up nice! New paint, grounded grids, soft key upgrade, etc. Ran full power with his tubes.
So - what to do about a PS...
See attached. I am taking a Antek 8T650 and a Harbach doubler board and making a power supply to run the 3-500 at 3500V. Hammond makes a enclosure that looks almost identical to the L4-PS enclosure. I think this will work FB with my single tube. Perhaps it may even have enough current to run two if I decide to drop more Benjamins on one. Transformer is a 800VA unit that makes .62A on the secondary. Pretty close to the OEM supply. I think it will drive one tube just fine at 3500v @ 400ma.
I will let you guys know when I fire it up.
On edit - running Duncan's amp PS program, using the actual winding resistance of the transformer, I think I will be ok. The output voltage is estimated at 2800V at 560ma with a 5K ohm load. Running the load as constant current with steps of 400ma and 800ma, it will make 3200V@400ma and will do 2800V@700ma. I think it will sag if I drive it to full power with 2 tubes. With 1 tube this might just work FB!
John
* L4B-Antek PS.pdf (726.48 KB - downloaded 404 times.)
« Reply #1 on: August 11, 2019, 03:07:44 PM »
That xformer is a beast.
It will be OK at full power ssb if you want to run legal limit.  1.5kw pep.  The factory SB220 xformer is 600 or so VA.  The factory L4B xformer is appx 800VA.
You have to input it as a .96kva xformer.  Uts designed to run at 50 hz, and on 60 it's about 20 pct better, give or take.
They do make a better one.  950 volts AC output.  It's almost twice as much however.
« Reply #2 on: August 11, 2019, 07:15:24 PM »
I like those Antek toroids and have bought quite a few over the years ... be sure to test them on receipt ... have had 1 or 2 bad small ones but Antek made good on them with no hassle .... until we find out more on manufacturing methods (like a doa dissasembly) I would only run one hv toroid with the secondary windings in parallel not in series .... afaic we had a discussion on here a few years without getting to a final answer ... I would use 2 smaller toroids stacked
as far as the L4B is concered it is a good rf box that needs more cooling air .... suggest cascading centrifugal blowers by adding a flange on the air input, a connnecting hose and a supply blower .... this can be cherry
« Reply #3 on: August 11, 2019, 09:38:07 PM »
I've run that one in series.
And the secondary isolation is 3.5kv rated.
WZ1M
« Reply #4 on: August 12, 2019, 03:28:29 AM »
Just so happens I have an LB-4 plate transformer. Cusyomer sent it in for a rewind and never paid for it. For some reason, after closing up shop, I hung on to this beast. Heavy to ship so its going to be a pick up only near Bangor Maine.
Gary
w9jsw
Two shots of Whisky
« Reply #5 on: August 12, 2019, 06:47:13 AM »
This one is hard to beat at $115 shipped. A bargain.
Got it mounted this weekend along with the harbach board, will do the under chassis wiring next. I was able to get the exact Drake power cabling on the bay as well as a connector so this is going to look almost OEM.
Only 1 day off this weekend so limited shack/bench time.
John
« Reply #6 on: August 12, 2019, 09:57:20 PM »
Shane ur not getting the point just yet .... the 3.5kV isolation rating is from the whole secondary to the whole primary not from secondary winding to secondary winding ... if the hV toroids are made like the lower voltage models then the primary is bifiliar wound and the secondaries are bifiliar wound ... this means that the secondary to secondary insulation is  the 2 coats of enamel between the windings .... now do you see my concern ?
« Reply #7 on: August 12, 2019, 10:57:52 PM »
I did miss that it's primary to secondary isolation.  But that is what I'm most concerned with when I build....  Not blowing every MOV in my house.
As I've said, I've built with that xformer.  I know a couple other people using either that one or their beefier ones.
Sure, it's anecdotal evidence, but it's what we have for now.
w9jsw
Two shots of Whisky
« Reply #8 on: August 24, 2019, 11:12:20 AM »
Almost there. Need to add the HV fuse. Will trim up the extra Trans wires after I test it out.
Decided to add a Harbach SoftStart/SoftKey/Bias board as well, so I took the relay out of the PS chassis. I could do it all on perf board but the Harbach board is only $90 fully built. Parts cost almost that much. Pretty reasonable and looks professional. The softstart will also be good for the filaments.
John
* L4B-Antek PS.pdf (726.48 KB - downloaded 410 times.)
« Reply #9 on: August 24, 2019, 08:20:52 PM »
How is the 813 rig coming>>>>>?
w9jsw
Two shots of Whisky
« Reply #10 on: August 25, 2019, 07:36:43 AM »
Steady progress. Just received some more hardware to make the mounting tasks easier. Mounting the control chassis and the modulator chassis into the frame to finalize positioning. Then start cutting holes for power routing across all of the chassis. Lots of metal work.
Been working with Phil on some regulators for the grids. For Grid 2 I now have planned a clamp regulator built on one of my PCBs that has an adjustable limit at 80-90ma. Also a -75 regulator that is a variation of a design he used for his DX100 mods.
Rethinking the supplies. I had planned to use bigger transformers that I had on hand. As I started to lay it out I realized that they are way overkill. Going to use some of these nice Antek 50VA and 100VA transformers fed into the PCB that have a bridge rectifier and large cap. Much cleaner and they are not that expensive.
* PCB_Reg0PCB.pdf (17.31 KB - downloaded 434 times.)
* Regulators Adjustable and Fixed for JW.pdf (74.81 KB - downloaded 426 times.)
« Reply #11 on: August 27, 2019, 09:04:28 PM »
What is the range of adjustment for the regulator (negative).
I need an adjustable -50 to -150 volt source at maybe 100 mils...  Bias supply for a pair of 8930s I picked up here awhile back.
w9jsw
Two shots of Whisky
« Reply #12 on: August 28, 2019, 06:49:27 AM »
I am going to breadboard it with a trans on a variac so will let you know what I see. Phil will know better since he designed it. If it test out good, I think I will make some pcbs. Why not?
I finished the L4B PS but now have to run a 230V circuit from my panel over to the bench, and build a tuna. My QRP tuna is no good for this rig or the 813 one. Going to build Tom's.
Also, been looking at my doublet outside. I think I need to do some tree trimming before I throw some power at it. Pretty close to some branches that don't care at 50W output. They will at QRO.
John
w9jsw
Two shots of Whisky
« Reply #13 on: September 17, 2019, 06:34:57 AM »
This project is done. PS makes 2900V under load. Drake puts out 700ish watts with one tube. Not bad. This will do as an interim until the 813 comes online. Also, I discovered that I can use the plate voltage meter for calibrating the 813 PS HV meter. Just unplug the PS and pull the tube. Hook up the HV and b- and there you are.
John
