March 28, 2024, 01:32:51 PM *
Author Topic: Turner SR90D Microphone Element Replacement  (Read 1686 times)
W1KSZ
« on: May 03, 2019, 07:40:51 PM »
The old Turner Mike sounds very Bassy on my newly acquired AF-67. It's not the Transmitter, since my
D-104 with a K7DYY Pre-Amp sounds great.
Any suggestions on replacing the element in the Turner SR90D ?
73, Dick, W1KSZ
KK4YY
« Reply #1 on: May 03, 2019, 08:06:36 PM »
Hmm.
Is it the SR90D-5 high impedance (25k ohm) or the SR90D-6 low impedance (200 ohm)?
W1KSZ
« Reply #2 on: May 03, 2019, 08:30:28 PM »
The Mike says Hi Impedance, but the Mike Switch in the back looks like it
got switched to the Carbon Position (up).
Guess I need to re-test it.
Thanks for the lead.
73, Dick, w1KSZ
W1KSZ
« Reply #3 on: May 04, 2019, 05:00:43 PM »
Yep, screw loose in cockpit !!
Switch was on Carbon side. Sounds better when switched to Crystal.
But, the D-104 with the K7DYY Pre-Amp sounds a lot better.
Tnx for the replies.
73, Dick, W1KSZ
