April 20, 2024, 08:58:52 AM *
Author Topic: Fixed my own R-390A micro switch  (Read 2097 times)
W8ACR
254W
« on: April 23, 2019, 11:32:46 PM »
I have recently acquired a very nice Collins R-390A that would not turn off. As I understand it, the 26Z5W rectifier tubes were commonly replaced with solid state diodes, and this sometimes caused the contacts in the ON-OFF microswitch to weld together due to current inrush. Sure enough, I looked at the power supply subchassis, and there were two diodes, and no tubes. I took the diodes out and plugged in two 26Z5W tubes, and promptly blew the AC line fuse. I found out that one of the tube sockets was damaged and shorting to ground. I replaced both tube sockets, and plugged the tubes back in, and success! no more blown fuses. One problem fixed.
The receiver would still not turn off, and I figured I would have to find a suitable replacement switch. But as a last ditch effort, I thought I would try to repair the switch. I took off the front panel, and getting to the switch was relatively easy. The switch was designed so that it could be carefully pryed open, and just as I expected, the contacts were welded together. Using a jewelry screwdriver, I carefully and gently worked on separating the contacts. To my surprise, they actually separated and looked undamaged. I put everything back together, and all is well.
I just thought I would share this story in case someone out there may have a similar problem. I really did not think I would be able to repair the switch. and maybe I was just lucky. Better to be lucky than good. Grin
Ron W8ACR
WD8KDG
« Reply #1 on: April 24, 2019, 12:16:52 PM »
Ron,
Somewhere in the past there has been another fix for what ails you. A resistor & cap are used to suppress the arc when those contacts open.
Might find it here: https://www.r-390a.net/
or: http://mailman.qth.net/pipermail/r-390/
Craig,
« Reply #2 on: April 26, 2019, 11:04:43 AM »
I sent you a PM, Ron, there were a few switches on epay... also almost any suitably rated microswitch could be
subbed into that spot, would need a suitable physical dimension, but there are a lot to pick from.
glad you go it fixed - I had one that was really well fried in an R-392...
WD8KDG
« Reply #3 on: April 26, 2019, 12:53:04 PM »
Found it in my notes:
Added a 0.01mF 1KV ceramic cap in series with a 220 ohm resistor across the function switch contacts. No welded contacts since.
Craig,
