March 29, 2024, 03:32:19 AM *
Author Topic: Drake L7 Power Supply  (Read 2205 times)
WB4YVO
« on: March 02, 2019, 04:11:58 PM »
All, I need to increase this supply to 3KV at 1 Amp.  Can it be done..
Skip
W1ITT
« Reply #1 on: March 02, 2019, 04:43:15 PM »
A number of amateurs have built external supplies for the L7, and Peter W Dahl company used to supply an external plate transformer for it that goosed voltage and current available.  As I recall, the windings in the stock transformer use up all the space within the cores, so even the crazy option of rewinding it wouldn't work.
I say "crazy" because I'm in the learning curve of winding, from scratch, a plate transformer on C-cores.  It's good fun.  Look up KF8OD's web page for more inspiration.  But, to answer your question, if you want better plate voltage, build a supply and design to suit your own requirement.
w9jsw
Two shots of Whisky
« Reply #2 on: March 04, 2019, 07:36:00 AM »
I have an L4B that came without a PS. I am building a Plate modulated 813 rig and am building the PS in a compatible way so I can also use it on the L4B.
See the attached schematic. Note that it is not complete as I am changing the mains switch to a latching starter relay. My iron came from a Gates BC-1T. 2500V at 1.5A.
John
* 813 Transmitter.pdf (1273.15 KB - downloaded 212 times.)
