April 23, 2024, 01:31:59 PM *
Author Topic: Kenyon transformer and choke info needed.  (Read 2340 times)
W8KHZ
« on: January 27, 2019, 06:51:10 AM »
Hi guys,
I have a medium sized Kenyon plate transformer and choke that I need info for. They are as follows:
Plate transformer   T-670
Choke   S-9947
Does anyone have any info on these?
Thanks!
Brian - W8KHZ
Currently running a big homebrew transmitter (pair of 250THs modulated by a pair of 810s) paired up with a National HRO-50.  I also run a BC-610-I / NC-2-40D combo which is a lot of fun too.
Catch you on 75M AM!
w9jsw
Two shots of Whisky
« Reply #1 on: January 27, 2019, 11:20:45 AM »
I took a look at some of the Kenyon catalogs on the Bunker of Doom but could not find anything. You may need to measure the resistance and inductance, weight them and then try to match them up as best you can with the specs in the catalog. Kenyon used to make a lot of custom stuff and the numbers were unique and not listed in the catalogs.
John
KC2ZFA
« Reply #2 on: January 27, 2019, 01:06:45 PM »
the S- unit doesn't look like a Kenyon...
The T-670 is in the attachment.
W8KHZ
« Reply #3 on: January 30, 2019, 10:55:16 AM »
Thank you for this info. Its a big help!  The "S" model chokes are in fact Kenyon (They have a Kenyon tag on them) but maybe made for a special application or customer?
Brian - W8KHZ
« Reply #4 on: January 31, 2019, 09:46:44 PM »
There are a few Kenyon parts here with numbers that are not in any document I have ever found. The only thing to do is measure.
