March 29, 2024, 07:50:54 AM *
Author Topic: KiwiSDR Online - CT/MA Border  (Read 6607 times)
N1NTE
« on: November 02, 2018, 01:37:52 PM »
0-30 MHz KiwiSDR connected to an 80-10m OCF dipole at 65 ft.
http://sigmasdr.ddns.net:8073/
Feel free to use it.
- Rob
« Reply #1 on: November 02, 2018, 05:49:45 PM »
Is there a Store function on this SDR? It sounds good on locals to the CT area right now 5:50 PM.
Over.........Terry
N1NTE
« Reply #2 on: November 02, 2018, 05:54:19 PM »
There is not persistent freq storage but you can click on the tabs on the top. I have the common AM freqs there.
- Rob
« Reply #3 on: November 02, 2018, 06:02:02 PM »
OK Thanks, BTW, it has a better sound than the other sdrs in the area.. Thanks for putting it on line! There are quite a few that use the software you are using but they either have lousy locations or antennas and are useless. Some have a 4 person limit? Is you sdr set up that way?
Terry
N1BCG
« Reply #4 on: November 02, 2018, 10:28:05 PM »
Since it’s a Kiwi SDR, you can pre-tune the receiver by including the frequency and mode variables in the URL. For example, to hear 3885kc in the AM mode with a zoom of “10” bookmark:
http://sigmasdr.ddns.net:8073/?f=3885amz10
Change “am” to usb, lsb, cw, etc for other modes.
N1NTE
« Reply #5 on: November 03, 2018, 05:46:42 AM »
Terry
Yes, there is a 4 user limit if you want waterfalls on each slot. It can be configured for up to 8 users without waterfall on most of them. Yes, many online SDRs have poor antennas but a significant amount of them are set up for MW listening, not SW.
It is interesting to watch signals on both mine and Steve's, WA1QIX (who has a very good SDR). You can pretty much predict QSB as it traverses north to south or vice versa.
And Clark is correct, you can bookmark and use the URL with the frequency, mode, and zoom level as a shortcut.
- Rob
VE3ELQ
« Reply #6 on: November 03, 2018, 08:54:57 AM »
This works very well for me as a valuable tool for TX testing. Just the right distance from my QTH on the eastern end of lake Ontario and with a good antenna.  Many thanks for this.
Best 73s  Nigel
A "Tube Free" zone.
« Reply #7 on: November 03, 2018, 03:47:55 PM »
I can't seem to load the sdr from the link or the one by Clark? Maybe it's off the air right now?
UPDATE: It works on Chrome but not on Firefox? Firefox seems to be endlessly updating their software? Is anyone else having a problem with Firefox loading this SDR? My version of Firefox is 63.0.1 (64 bit) which is the latest update.
Nother update: I copied the sdr URL from Firefox to chrome and it worked? Maybe I have something set up wrong with Firefox?
« Reply #8 on: November 03, 2018, 06:15:40 PM »
T,
I'm also using 63.0.1, and not having any problems with the site.
Fred k2dx
« Reply #9 on: November 03, 2018, 06:19:07 PM »
It's working here, Firefox v 63.0, 64bit
« Reply #10 on: November 03, 2018, 07:15:14 PM »
Thanks guys, interestingly is the fact that none of the KiwiSDR Online receiver will not work on Firefox on this computer? Everything is set to the default settings on Firefox? Maybe I have one of those dag-burn govern-meant bugs implanted in me computer? I would not understand why that would be since I know no secrets etc? Maybe that explains that tractor trailer load of 8 track tapes parked outside?
WA2SQQ
« Reply #11 on: November 03, 2018, 07:26:52 PM »
Working very nice from down in NJ. Using Firefox / Win 10 + Ipad 10.5 PRO.
Thanks for sharing this!
« Reply #12 on: November 04, 2018, 05:29:30 PM »
Is it down?
"Server Not Found"
EDIT
Then it worked... Cheesy
Can I get rid of that blasted "waterfall" and see a spectrum display??
VE3ELQ
« Reply #13 on: November 04, 2018, 06:15:58 PM »
Is it down?
"Server Not Found"
EDIT
The note in there states it may be down when he is using his station and to try later, could be what happened.
Click on the green Spec box and you will get a spectrum display in the upper area.
73s  Nigel
A "Tube Free" zone.
WA2SQQ
« Reply #14 on: November 06, 2018, 09:01:01 AM »
I was listening last night when Steve was working Nigel. Nigel was just at my local noise level. Online SDR to the rescue and I was able to hear both sides
WA2SQQ
« Reply #15 on: November 06, 2018, 03:26:07 PM »
FYI, 2 things I noticed:
1. Compared to Steve's SDR, the audio here has less hi freq audio response.
2. I've also noticed that the AGC is usually on, and like most SDR's they can overload very easily. Manual gain adjustment really improves how it sounds.
N1NTE
« Reply #16 on: November 06, 2018, 08:28:05 PM »
The KiwiSDRs have a passband of about 12kHz max. When you chose AM mode you can drag the yellow passband sliders out a bit more than the default.
Also, the BeagleBone server that runs it reboots in the wee hours of the morning (2 am to 6 am) when there are no users connected. It only takes 53 seconds to reboot so you don't have to wait long. Wink
The lack of adjustable gain control is a downside I agree. Despite these downsides the KiwiSDR is a turnkey solution for $220 and allows others to share my antenna when I'm off doing other things. Judging from the number of visitors logged there has been much more interest than I expected.
- Rob
WA2SQQ
« Reply #17 on: November 07, 2018, 08:44:34 AM »
Lack of adjustable gain? If you click on AGC, you can disable it and manually set the gain. Dont get me wrong, it works incredibly well!  I appreciate having it available. FYI, I was doing some AM BCB DX'ing with it. Interesting, being able to listen to some freq's that are locally occupied by 5KW stations. Thanks
N1NTE
« Reply #18 on: November 19, 2018, 06:40:16 PM »
Here is a list of some of the newer KiwiSDRs that just came online:
     https://www.hfunderground.com/wiki/index.php/KiwiSDR
W4EWH
« Reply #19 on: November 20, 2018, 12:17:02 AM »
- Rob
It sounds really nice: great to hear WA1HLR again! I copied some stations on AM from Virginia, one from New Bern, NC, and a couple of sideband signals.
THANK YOU!
W4EWH
