April 16, 2024, 11:43:45 AM *
Author Topic: BIFET Compressor Mic and IC-718 by WA7JHZ  (Read 25779 times)
« on: October 30, 2018, 02:24:25 PM »
The attached JPG shows what I've been doing with my BIFET compressor mic and Icom IC-718. Followed by a decent linear amplifier, it is hard to tell the difference between it and a modified broadcast AM transmitter.
* IC-718 AM Modulator and BIFET Compressor Mic 10-19-2018.jpeg (429 KB, 1820x1140 - viewed 1491 times.)
« Reply #1 on: October 30, 2018, 02:26:18 PM »
The attached JPG shows a reversed order between the 4 kHz LPF and AGC/peak-limiter on my proposed compressor mic circuit. The complex phase shift of the LPF occurs before the AGC/peak-limiter, and its noise and distortion are low enough to allow this. Note that I've also added a positive modulation control circuit (U12).
* BIFET Compressor Mic with no Boost Pos+Neg dynamic 10-30-2018.jpeg (298.18 KB, 1920x1080 - viewed 1425 times.)
ab3al
« Reply #2 on: October 30, 2018, 05:48:00 PM »
does this improve the audio bandwidth of the transmitter or just controll the agressive agc. looking at it from my phone cant see to well
« Reply #3 on: October 31, 2018, 11:07:51 AM »
This circuit is to control modulation levels. There is a 4 kHz lowpass filter to limit higher frequencies.
In general, the only way to improve the audio bandwidth of a transmitter is to modify the transmitter, not with external boxes. Yes, an equalizer can overcome some inadequacies but there are limits to this approach.
